AMI Background Music Systems 1957-76
Continuous Play   •••   HC-120   •••   G120   •••   K200 Halfback
HBB200
•••   HA500   •••   HA600   •••   HA700   •••   HBE200
Customusic®  Programaster
•••   CPC-60-1   •••   CPC-75   •••   CPC-10-1   •••   CPC-180
Continuous Play Unit (1954)
Billboard, July 10, 1954, p. 86
AMI Continuous Play System
HC-120 (1954/55)
HC: Continuous play hideaway with extra speaker for background music
AMI Musikbox Jukebox HS80 HS 120 HC 80 HC 120 Hideaway
G120 Background Music System (1956)
Fotos und Information Terra Technica Museum
Die Box ist auf kontinuierliches Spiel eingestellt. Selektor, Münzung, Kassa, Lautsprecher, Beleuchtung und Titelhalter sind nicht vorhanden.
Das Gehäuse ist wesentlich kleiner als die normale G-120 ausgelegt.
Die Box spielt ohne Unterbrechung sowohl "A" als auch "B" Seite jeder Platte ab. Ein Verstärker für Remote-Lausprecher ist vorhanden.
  The box is set to continuous play. There is no selector, coin mechanism, cash box, loudspeaker, lighting nor title holder.
The cabinet is considerably smaller than the regular G-120.
The box plays both "A" and "B" sides of each record without interruption. An amplifier for remote speakers is available.
AMI G120 background Music System
HBB-200 – Continuous Play Hideaway Unit (1957-60)
- Sorry, no picture yet -
Background Music Program System HA 500 (1959 ?)
JPK-200: Background Music Unit; so called "Halfback"; first introduced in May 1960
There might have been different versions available of model JPK.
1. Version:
  • Random play feature
  • Amplifier: R2017 with L2156
  • Speaker: one low range and one horn
  • Front glass: "AMI", "The World's Finest Music"
  • Keyboard: 100 selections but holds 100 records
  • Keylock "mode" switch in back:
    when repositioned all of the machine lights shut off and play the other 50 records in series
  • Two counters: one for normal, one for "background" play
  • Automatic selector with seven wire bundle connectors – related to the "background" music mode.
AMI JPK-200
2. Version:
  • Amplifier: R2017-A with L2156-B
  • Date on certain parts: 30. Juni 1965
  • Keyboard for 200 selections (A – K / 1 – 20)
  • Front glass: "AMI" and "The World's Finest Music"
  • Mechanism: 995
AMI JPK-200 Mechanism 995
AMI JPK-200
3. Version: Made of a manual selection AMI K? Photos courtesy of www.radioamfilochia.gr
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
Background Music Program Center HA-600 & HBE-200 (1960-62)
 AMI Rowe Background Music System HBE-200, HA-600
Photos ourtesy of W. Fredrickson
Background Music Program Center HA-700 (1961-62)
 AMI Rowe Background Music System HA-700
Background Music Center "Customusic® Programaster" (1962) - photos by courtesy of Benjamin Thoburn
Designer
Cabinet:
Melvin Herman Boldt, patent "Combined Tape Cartridge Player and Programmer Cabinet" D204,270 - filed 1964
Mechanism: Franklyn G. Nickl, Patent "Playback Apparatus for Multiple Magnetic Tape Cartridges" US3,431,367 - filed 1965
AMI Rowe Background Music System HA 600 HA 900
AMI Rowe Background Music System Programaster
Background Music System "Customusic®  Programaster"  (1966) - no picture yet
More information about Background Music: A Background Music Report (pdf)
Background Music System "Customusic®  Programaster" CPC-60-1 (1975) - photos courtesy of Schwab Automaten
Capacity: six endless loop tapes for 60 hours of music without repeating a selection.
AMI Rowe Background Music System CPC-60-1
Background Music System "Customusic® Programaster" CPC-75 (1975)
Same features as CPC-60-1 except that one tapes is replaced by an anouncement tape
- no photo yet -
Background Music System "Customusic®  Programaster" CPC-10-1 (1975)
with one ten hour cartridge (tape); five additional ones can be stored within the unit. Cartridges are changed manually
- no photo yet -
Background Music System "Customusic®  Time Master" CPC-180 (year: ?)
 AMI Rowe Background Music System CPC-180
