AMI und Rowe/AMI Musikboxen im Archiv von Jukebox-World |
Electrical devices in Australian AMI &
Rowe jukeboxes |
Speaker |
This is the top speaker assembly as removed from an Australian Made MM-2, but were also used in the MM-3,MM-4. May have been used in the MM-1, but might have had a different shaped moulded plastic back cover than this one. Im quite sure this same model of speaker was used in all MM-1 to MM-4 machines.
I think from memory that the speaker was screwed to the metal plate from behind, and then the cover was placed over it and screwed in from the front of the plate.
The speaker used is an MSP (Manufacturers of
Special Products) Australian made unit. (Note, they also made
fluorescent ballasts used in some but not all Australian AMI machines)
The pink material was fibreglass wool, and would leave you itchy if you
got it on you.
While this pic is not of a jukebox, this
speaker is identical to the 12" unit used in Australian made JEL, and
Diplomat machines - and possibly others. (Note: The transformer shown on
the speaker in this pic was not used in the AMI machine. From
memory the label and stamp were same too.) |
Plugs |
Also on the previous subject of mains plugs
used internally in Australian Made Machines, where I said USA type plugs
were always used. The exception is with the G-80. Continental J, K,
Diplomat etc. used USA plugs.
Its unknown if there were followed standards for mains plugs across Australia in the 1950s when the machine was made, I remember reading years back that there were reports of various different types of mains plugs used in some regions, and cases of AC or DC being used in different areas. For example Western Australia was still using 250vac mains until early 1990s. The rest of the country used 240v. Please ignore that grey inline plug and socket next to the amp, these were added in the 1970s in order to fit a standard AUS mains plug, not only for bench repair of the amplifier, but and to provide an earthed plug and socket to comply with Australian wiring rules, They are not original. The green earth wire shown was added later too and was not original. Original was fig 8 lamp wire (white in colour) that was used. |
Dia-Projektor – Slide Projector |
Service Manual: "A slide projector, mounted at the top center of the phonograph, shows slides promoting record play. The slide projector holds eight 35MM slides and shows then continuously; one every 15 seconds." This was removed years ago from an Australian made MM2, but have seen these also used in Australian MM3, though may possibly need different mounting brackets as the beam goes upwards rather than sideways. This unit is a 240v version for Australian market - even though it has the USA plug.
Amplifier |
Amplifier RA-145:
