Wurlitzer Jukeboxes & Wallboxes im Archiv von Jukebox-World
Wurlitzer 1600   •••   1650 (1953)
Wurlitzer 1600 A, 1650 A, 1600 AF und 1650 AF (1954)
Wurlitzer 1600 (1953)
Wurlitzer 1650 (1953)
- sorry, no photo yet -
78, 45 or with kit 109 adjustable for 33-1/3 RPM
Deluxe: cabinet in  dark walnut finish
Custom: cabinet in blonde, blue, red or mahagony vinyl plastic
W 1650
Wurlitzer 1600A (1954)
Wurlitzer 1650 A (1954)
45 or 78 RPM; cabinet dark walnut finish
standard sound system
 45 RPM; cabinet dark walnut finish
Wurlitzer 1600AF (1954)
Wurlitzer 1650 AF (1954)
45 or 78 RPM; cabinet limed walnut,
High Fidelity sound system
Wurlitzer 1650 AF
Models 1953 Models 1954
Wurlitzer 1600 and 1650 (1953):
Cabinet in Deluxe and Custom version with glass pilaster,
Top valance "Wurlitzer - the name that means music to millions", silver background and red mechanism cover
Dimensions: 55 x 33-1/16 x 28" (H x W x D); 350 lbs
Wurlitzer 1600A, AF and 1650A, AF (1954):
new cabinet design: plastic pilaster, new center grill with three bars, red background, grey chassis in hammertone
top valance "Wurlitzer"
Dimensions: 53-1/2 x 29-3/8 x 26-7/8" (H x W x D); 315 lbs
Wurlitzer 1600: 78, 45 or with kit 109 adjustable for 33-1/3 RPM
Wurlitzer 1600 A: 45 or 78 RPM; cabinet dark walnut finish
Wurlitzer 1600 AF:
Wurlitzer 1650: 45 RPM
Deluxe: cabinet in  walnut finish with natural birch trim
Custom: cabinet in blonde, brown, blue, red or mahagony vinyl plastic
Wurlitzer 1650 A: 45 RPM; cabinet dark walnut finish
Wurlitzer 1650 AF:
45 RPM; cabinet limed walnut
Wahlen / selections 48
Lampen / lamps 1600 / 1650: cabinet: 2x TL 20 W/24"/T12
1600A / 1600AF / 1650A / 1650AF: cabinet: 4x TL 20 W/24"/T12
Verstärker / amplifier 1600 / 1650:
518 - valves 5U4G, 6L6G, 6J5  6SN7GT, 6SJ7, 12AU7, 12AX7
1600A / 1650A:
526 - valves 5U4G, 6L6G, 6J5, 6SN7GT, 2x 6SJ7, 12AU7, 12AX7
1600AF / 1650AF:
526HF - valves 5U4G, 6L6G, 6J5, 6SN7GT, 2x 6SJ7, 12AU7, 12AX7
Lautsprecher / speaker electro-dynamic, 8 Ohm, field coil 5200 Ohm
Tonabnehmer / cartridge Cobra
Sicherungen / fuses 2A, 15A, 800 mA; 3.2A
Schlüssel / key 1600 / 1650: RW-49
1600A / 1600AF / 1650A / 1650AF: RW-85
Gehäuse / cabinet see upper description
Abmessungen / size 1600: 141 x 84,5 x 72 cm / 55-1/4 x 33-1/8 x 28"; 158 kg / 350 lbs
1650: 140 x 84 x 71 cm / 55 x 33-1/16 x 27-7/8"; 151 kg / 335 lbs
Zubehör / accessories 1600: kit 109 to adapt to 33-1/3 rpm
Wallbox 5206; Stepper
248 or 2 x 219; Booster 222; aux. amp 227; 5100 (beige), 5110 (beige)
Besonderheiten / specialties 1600: quick change from 10" 78 rpm to 7" 45 rpm and may easily be adapted to 10" 33-1/3 rpm
Jukebox-World
