Stereo equalizer pre-amp
Product 3 of 10
This stereo equalizer pre-amplifier is used when connecting a magnetic cartridge with low output to an amplifier made for ceramic or crystal cartridges actually.
Technical Specifications
Input Sensitivity5 mV / 100 KOhm / 1 KHz
Max. Input30 mV
Output450 mV / 100 KOhm / 1 KHz
Frequency Response18 Hz – 20 KHz
S/N Ratio> 50 dB
Power Connection Type15VDC / 200 mA
Dimensions100 x 65 x 35 mm
Weight200 g
A low interference might be possible. To avoid this the pre-amplifier should be installed in a distance of minimum 20 cm to AC fields like transformers, motors, AC power lines etc.
The pre-amplifier is for use of 230V and comes with an external power supply.
Reviews
* incl. tax, plus shipping
