Idler tension spring
Product 12 of 17
This idler tension spring is used in the turntable drive mechanism of various AMI and BAL-AMI models (model F 120 and up).
The original part number is F-907, later renumbered to 2-00907-00. In second picture the spring is marked.
Worn springs can cause sound distorsions. In this case next to the spring the idler wheel and TT grommets should be checked as well and eventually be replaced.
Reviews
Mano writes: 31.03.2024
Like original quality!
peter writes: 18.09.2022
Good quality and service
declan writes: 30.06.2021
Eine schöne weiche Zugfeder. Perfekt.
Thomas writes: 03.07.2020
Feder, Gummi, Puffer und Lager in 10 Minuten und um 27,40 Euro gewechselt- sie dreht wieder perfekt mit gezählten 45 Umdrehungen! danke an das Team Starmann!
Robert writes: 04.12.2019
parfait
Jürgen writes: 25.10.2018
Passt alles gut
Thomas writes: 28.02.2018
Wie immer alles bestens
* incl. tax, plus shipping
