Rubber ring for idler wheel
Product 11 of 17
Item #: A190
AMI F80 to Continental 2 (45 rpm) and BAL-AMI
Cart deactivated
AMI did use the shown idler wheel for the models F 120 up to the Continental 2(only 45 rpm). It was used on (some) BAL-AMIs, too. The bushing has a 4 mm hole (# F-898).
  • F-80, F-120
  • G-80, G-120, G-200
  • H-100, H-120, H-200
  • I-100, I-120, I-200
  • J-100, J-120, J-200
  • K-100, K120, K200
  • Continental – nur 45 rpm
  • Continental 2 – nur 45 rpm
  • einige BAL-AMI
We did make reproductions of the rubber ring, so you don't need to replace the complete idler if not necessary. If needed we offer complete idlers with a 4 mm hole too - compare A006. The second photo shows an original idler wheel for demonstration only.
Price is for one rubber ring.
The idler wheel assembly F-898 is also found in the receiver-selector assembly in record changer model 900 used in models AMI G-200. The rubber replaces the old one, too. Later models AMI H, I etc. do not use this idler wheel in the receiver-selector unit.
Reviews
Mano writes: 31.03.2024
Best quality you can find!
Melvin writes: 03.06.2023
Well made of high quality rubber, I've used many of these rings, never an issue, easy to fit!
Ralf writes: 19.02.2023
Alles bestens, sehr gute Passform. Top Service, immer wieder gern.
Alles bestens. Sehr gute Qualität, passt genau. Immer wieder gern.
Olivier writes: 14.01.2022
Perfect fit, excellent reproduction part, thank you for providing an excellent replacement idler ring.
Michael writes: 15.02.2021
Passt perfekt! Vielen Dank!
Peter writes: 16.12.2020
Passte einwandfrei. Sauber hergestellt.
Thomas writes: 03.07.2020
Feder, Gummi, Puffer und Lager in 10 Minuten und um 27,40 Euro gewechselt- sie dreht wieder perfekt mit gezählten 45 Umdrehungen! danke an das Team Sta(r)mann!!!
* incl. tax, plus shipping
