Cash box door Deutsche Wurlitzer
Product 10 of 85
Item #: WD300
for various models up to OMT
die cast aluminium, 169 x 169 mm
Cart deactivated
You can't tell the difference from the original!
True to original in all details.
This cash box door is an exact reproduction made from aluminium in the process of high pressure die casting.
The surface is very smooth and only needs a little bit of sanding before it gets primed or painted.
The German Wurlitzer did use these doors for many models throughout the years - even up to the OMT models.
Size : 169 x 169 mm
The door comes without a lock.
Please note:
For the use of these doors with the OMT models of the German Wurlitzer the three notches at the bottom might need to be removed by grinding or sanding (see picture #7).
Reviews
* incl. tax, plus shipping
