TT drive belt, type B
Product 7 of 26
Item #: NSM002
NSM 1967/68 - 1976, Ø 57 mm
fits also early Eltec F60
Cart deactivated
Drive belts show wear within the years. They can get hard or brittle, they get longer or a notch can be seen after many years. A cranky sound or one with distortion will be the result.
NSM: Exact reproduction of the NSM TT-drive belt for the NSM models 1967/68 to 1976 - see listing. Original part number 207353 (*) and 23360.
The left hand photo shows part of the mechanism (33/45 rpm) where the drive belt is guided over two idler wheels. One belt per NSM jukebox is required.
  • Consul 130D*
  • Hit 130D*
  • Festival 130D*
  • Prestige 160*, Prestige 160A, Prestige 160B, Prestige 160Bb, Prestige 160C, Prestige 160D
  • Prestige 120, Prestige 120A, Prestige 120B, Prestige 120Bb, Prestige 120C, Prestige 120D
  • Consul 160, Consul 160B, Consul 160C, Consul160D
  • Consul 120, Consul 120A, Consul 120B, Consul 120C, Consul 120D
  • Hit 120, Hit 120A, Hit 120B
  • Century 21
Earlier models for 45 rpm only use two drive belts guided over one idler wheel only - compare NSM001.
On NSM models using the so called "E" technology the TT is driven directly, hence no drive belt is needed.
Eltec F60: The early production run uses drive belts instead of drive wheels - see photos #3 and 4. These NSM drive belts can be used therefore. The motors might need a slight adjustment in their position. Two belts per Eltec F60 wallmount jukebox are required.
Reviews
Hartmut writes: 09.08.2023
Passr
Fasching writes: 28.12.2022
War meine erste Bestellung, bin sehr zufrieden, Preis ist ok, Mail Anfragen werden sehr rasch beantwortet,
Sascha writes: 13.08.2022
Wie immer - auch hier das Ersatzteil (Gummiring) perfekt - und die nächste Party kann kommen.
guy writes: 11.08.2022
Bonjour,envoi conforme à la commande,produits de bonne qualité mais prix beaucoup trop élevé pour des petites courroies en caoutchouc !!!!.J'ai malheureusement été obligé de vous les commander pour faire fonctionner mon appareil ......
Waltraud writes: 03.12.2021
Alles prima
Fritz writes: 16.10.2021
Super Qualität! Sehr genaue Verarbeitung! Sehr empfehlenswert!
Kees writes: 25.05.2021
Past perfekt en ook makkelijk te verwisselen. Top.
Roland writes: 15.05.2021
Alles bestens, schnelle Lieferung.
Udo writes: 10.05.2021
Alles bestens, sehr gute Ware, freundlich wie immer - gerne wieder!!!
Christian writes: 08.05.2021
Passt super. Danke.
Roland writes: 20.04.2021
Top
Roy writes: 18.02.2021
As always the best quality drive belt I ever used, yes there are cheaper venders but you'll get what you pay for! With this drive belt your record will spin at 45 RPM without flutter
De beste kwaliteit aandrijfsnaar die ik ooit heb gevonden, ja er zijn goedkopere alternatieven maar je krijgt waar je voor betaald, deze snaren laten de draaitafel wel op 45 toeren draaien zonder te jengelen
remko writes: 18.02.2021
Perfekt, danke alles bestes wie immer, gute Ware schnelle Abwicklung,
Gerne wieder.
ANTONIO writes: 11.02.2021
Correspond exactement, top qualité.
Fonctionne parfaitement. Merci.
Kai writes: 30.01.2021
..tolle Qualität und wie immer top Abwicklung
vm writes: 28.01.2021
Working very well
Dirk writes: 02.12.2020
Alles gut; passt und funktioniert!
Tim writes: 14.10.2020
Funktioniert perfekt!
Walter writes: 01.10.2020
Perfekte Ware.
Helmut writes: 19.06.2020
Perfekt, danke alles bestes wie immer, gute Ware schnelle Abwicklung, Toll das es "Sie" gibt
John writes: 06.05.2020
Perfekt,wie orginal super
Michael writes: 06.03.2020
Funktioniert bestens
Bram writes: 11.02.2020
Goede kwaliteit snaar en nette communicatie over de levering
Peter writes: 17.12.2019
Hans-Joachim writes: 19.10.2019
Alles prima perfekt gepasst
Roy writes: 21.07.2019
Perfect fit and quality As always.
Bernhard writes: 28.06.2019
Vielen Dank für die Zusendung der Antriebsriemen, ich hatte früher ja schon welche bei Euch bestellt.
Sie arbeiten hervorragend und die Boxenbesitzer sind froh, den Sound ihrer NSM-Geräte nun wieder ohne Geleier genießen zu können. Ist nun einmal ein typisches Verschleißteil bei Boxen dieser Generation. Vielen Dank!
Ralf writes: 20.05.2019
Herzlichen Dank für die Antriebsriemen.
Hab sie gleich in 2 NSM Boxen eingebaut und bin begeistert von der Qualität.
Roland writes: 10.12.2018
Super damit ist das Leiern weg
Danke
Martin writes: 20.10.2018
Prima snaar en is een aanrader om deze te vervangen om veel ergernis te voorkomen, snelle verzending
Christophe writes: 23.03.2018
bon produit, ne pas hésiter à remplacer les courroies qui sont bien souvent détendues
Waltraud writes: 12.12.2017
Sehr gute Ware und super schnellen Versand
Delahaye writes: 16.11.2017
Très bien pour nsm 120d
* incl. tax, plus shipping
