Ballast 2x20W / 120V
Product 8 of 10
Item #: L033
2 x 20 Watt, 120 Volt, 50 Hz
Cart deactivated
Old ballasts can cause disturbing noise and might be a danger if the shielding of the wires is brittle. We recommend to replace old ballasts.
This ballast is rated for 2 x 20 Watt fluorescent lamps at 120 Volts/50 Hz.
Size: 48 x 165 mm
Please check if the heat resistant material underneath the ballast is still ok.
A general note: To operate fluorescent lamps in jukeboxes three devices are needed: The ballast, the lamp itself and a starter. They have to match each other in value and voltage.
Limited availability! When stock is sold we can't get this item again.
Reviews
Wilhelm writes: 25.01.2022
schaut gut aus
* incl. tax, plus shipping
