78's needle
Product 1 of 14
Item #: N78-O
For various 78 RPM jukeboxes, NOS
Cart deactivated
This stylus, NOS, was used in the earlier 78 RPM jukeboxes. The needle was screwed into the cartridge. It is good for a tonearm weight of 1 - 4 oz. It was e.g. used in
  • AMI up to 1939
  • Filben Maestro
  • Mills up to 1942
  • Rock-Ola up to Model 1426
  • Seeburg Symphonola up to 1942
  • Wurlitzer up to 1945
Please note: This needle is only for playing original 78s. The high tonearm weight would destroy reproduction (vinyl) records.
Wurlitzer explains in their service manual for models 500 and 600 that this kind of needle is for use for up to 400 plays.
We send the needles in the original packing. The photos show that the lower shaft is slightly corroded. The tips are ok. Please order only if you can accept this.
The following links display photos of original cartridges to identify the needle you need.
AMI  |   Filben   |   Mills   |   Rock-Ola   |   Seeburg   |   Wurlitzer - USA
Reviews
* incl. tax, plus shipping
