Seeburg-Mono, 0.7 mil
Product 6 of 14
Item #: N363.07
Diamond tipped, Seeburg M100B to 201, for mono and stereo records
Cart deactivated
This stylus has a 0.7 mil diamond tip and plays both mono and stereo records very well.
New improved version! Strong output!
We inspect, adjust and stabilise each needle individually and test it on a restored HF100G.
You will hear the difference!
Please adjust tone arm weight to 5 grams max.
Make sure the styli get inserted completely into the cartridge. Careful cleaning of the slots might be needed and help.
It is also important that the tiny metal arm which holds the diamond tip can move freely and doesn't touch the housing.
The stylus is for use with the Pickering Redhead magnetic cartridge which is installed in the following Seeburg jukeboxes:
  • M100B
  • M100C
  • HF100G
  • 100W
  • HF100R
  • 100J
  • V200, VL200
  • KD200, KS200
  • L100
  • 101, 161, 201
  • Jukeboxes by German Gauselmann might be possible
  • Library Units 200LU1 to 200LU3
  • Custom Units 200CU1 to CU3
  • Console 200C1, 200C2
This item is non-discountable.
Tip: If only old mono records shall be played the straight needle with 1 mil diamond tip is the best way to go (item N363.1). It generates an even higher output - volume and dynamic are slightly stronger.
Note: The following links display photos of original cartridges to identify the needle you need.
Gauselmann   |   Seeburg
Price is for one stylus.
Reviews
Hans writes: 09.12.2023
Execellent sound. Full and with good bass. Has a strong output. I can put the volume 20% less when comparing with my previous needles.
Top service from Mr. Stamann. Arrived within 3 days carefully packed.
ALESSANDRO writes: 27.03.2023
Prodotto top! Le puntine suonano benissimo nel mio julebox Seeburg HF100G con un suono molto potente simile a quelle per i dischi MONO. Raccomandato!
Günther writes: 19.02.2023
Die Lieferung wie immer Perfekt
Die neuen Nadeln eingebaut,und mein Red head Tonsystem meiner Seeburg 201 hat wieder unvergleichbaren Sound.
Spitzen Produkt,100 Prozent zu Empfehlen.
Eduard writes: 28.10.2022
This once again improved version is very close to the original L-shape needles. The volume needs to be increased only a little. Great sound quality provided the redhead pickup is in a good condition. Can be highly recommended.
Bruno writes: 27.09.2022
Hat alles gut geklappt, Artikel so wie Beschrieben, kann noch nicht getestet werden da die Jukebox nicht vor Ort ist.
Alles speditiv erfolgt, so wie immer bei Stammanns.
Für alle Besteller aus der Schweiz ist es wichtig zu Wissen, dass die Lieferungen zwar direkt zugestellt werden, jedoch über den Schweizer Zoll laufen und dort zusätzlich verzollt werden müssen.
Für die beiden Nadeln im Wert von rund 90 Euro mussten Zollspesen in Höhe von über 21.-- CHF bezahlt werden.
Robert writes: 10.09.2022
I have had a Pickering 03D on my 100 R for years because the old redhead just didnt cut it anymore. I tried new needles from the US recently to five it another try but the sound was dead. As a last effort I bought a set from here. I recently installed them and the redhead again just to compare the 03D and the new redhead. Amazing sound once again in the redhead. As good as the old Pickering ! My 100R can proudly wear its factory redhead once again.
david writes: 19.08.2022
brilliant replacement and wonderful service as usual
Mikael writes: 05.05.2021
A good replacement needle
Gustav writes: 13.12.2020
Die besten Nadeln für das Redhead! Alle anderen Artikeln auch gut angekommen, aber noch nicht eingebaut - Bewertung dann später!
Stephen writes: 16.03.2020
Works great with Redhead Pickering mono cartridge, but be sure to push the stylus far enough down in the cartridge slot so that both electrical pads make contact with the cartridge. At one point I wasn't getting both channels from a stereo 45 until I realized only one channel was making contact. I pushed the stylus further into the cartridge and both channels came through..
Bernhard writes: 10.12.2019
Superschnelle Lieferung. Bin sehr zufrieden!
Alfred writes: 07.01.2019
Diese Nadeln funktionieren sehr gut.
Alfred Freinberger
Richard writes: 18.02.2018
Excellent quality timely shipping and good communication answering my questions prior to my placing an order.
Günter writes: 13.08.2014
Endich nach langem probieren und warten wieder eine Nadel mit hervorragendem Klangverhalten!
Hab sogar bei meiner KD 200 Bass und Höhen eine Stufe zurückgedreht. Diese Nadel ist ihr Geld wert.
Viele Grüße Günter Wild
* incl. tax, plus shipping
