Please see notes below.
Mirror glass "diese Platte spielt"
Product 3 of 101
Item #: WD106
Lyric 1961, German
Cart deactivated
This little mirrored instruction glass is mounted between the upright located tileholders in model Lyric by the Deutsche Wurlitzer in 1961. This glass is often broken or missing but is both optical and for the instruction an important item. It also holds the bracket for the record indicator lense.
The offered glass is metallised screenprinted like the original ones, thickness: 4 mm. The blue and red parts shine brightly and the holes for mounting the bracket are drilled of course.
The second photo shows an installed mirror glass and is for demonstration only
Check item WD107 for the English version.
Reviews
Andreas writes: 07.04.2020
Passt perfekt, da Löcher genau in der Flucht; Schaut wie das Original aus, was bei mir leider 2 x gebrochen war.
* incl. tax, plus shipping
