Please see notes below.
Cone tweeter
Product 38 of 53
Item #: SPHT60
Frequency 800 - 20,000 Hz, Ø 70 mm, 8 Ohm
Cart deactivated
High frequency speaker to replace damaged or faulty ones in jukeboxes of the 1960s era, e.g. Rock-Ola Rhapsody, and Wurlitzer OMT models, original part number 12941.
The speaker has an outer diameter of 70 mm for a cutout diameter of 64 mm and a depth of 29 mm. The layout of the holes to mount the cone tweeter match the original ones.
Frequency: 800 - 20,000 Hz
Impedance: 8 Ohm
Sound pressure: 90 dB
Musical power: 100 Watt
Rated power:
80 Watt
Voice coil: 0.55" (1.4 cm)
Outer diameter: 70 mm
Cutout diameter: 64 mm
Depth: 29 mm
Distance of holes, diagonal 74 mm
Manufacturer: Visaton
Datasheet:
All speakers with their values to compare: List of speaker
Reviews
JF writes: 07.08.2019
super
mike writes: 25.01.2018
Very nice speakers, work great in my NSMES11-0. With a slight modification. Best I could find. Thank you, Mike
* incl. tax, plus shipping
