Ballast 2x18W/20W, 1x 36W / 230V
Product 14 of 20
Item #: L040
1x 36, 2x 20 or 2x 18 Watt, 230 Volt
Cart deactivated
Old ballasts can cause disturbing noise and might be a danger if the shielding of the wires is brittle. We recommend to replace old ballasts.
This ballast is rated for fluorescent lamps with
or
2x20 Watt, 230 Volt
or
1x 36 Watt, 230 Volt
This ballast is rated for fluorescent lamps operated at 230 Volts. This can be suitable for jukeboxes
- operating at 230V regularly, e.g. models of Deutsche Wurlitzer, NSM
- of US manufactuerers prepared for export already - compare ID plate
- or the jukebox was converted to 230V at a later date.
Please check if the heat resistant material underneath the ballast is still ok. We offer replacements - see item V023.
A general note: To operate fluorescent lamps in jukeboxes three devices are needed: The ballast, the lamp itself and a starter. They have to match each other in value and voltage.
Reviews
* incl. tax, plus shipping
