Please see notes below.
Ballast 2x25 W / 120 V
Product 9 of 16
Old ballasts can cause disturbing noise and might be a danger if the shielding of the wires is brittle. We recommend to replace old ballasts.
This ballast is rated for 2 x 25 Watt fluorescent lamps at 120 Volts/50 Hz.
Size: 60 x 165 mm
Please check if the heat resistant material underneath the ballast is still ok.
A general note: To operate fluorescent lamps in jukeboxes three devices are needed: The ballast, the lamp itself and a starter. They have to match each other in value and voltage.
Reviews
* incl. tax, plus shipping
