Please read notes below regarding shipping, Brexit and more  ---  Play to help people from Ukraine
Ballast 4-8W / 110V
Product 7 of 13
Old ballasts can cause disturbing noise and might be a danger if the shielding of the wires is brittle. We recommend to replace old ballasts.
This ballast is rated for 4-8 Watt fluorescent lamps at 120 Volts/60 Hz.
Please check if the heat resistant material underneath the ballast is still ok.
A general note: To operate fluorescent lamps in jukeboxes three devices are needed: The ballast, the lamp itself and a starter. They have to match each other in value and voltage.
Reviews
Andreas writes: 21.11.2018
Das Alte raus, das neue rein und endlich kein Brummen mehr.
einfach anzuschliessen
* incl. tax, plus shipping
