Please see notes below.
JukeBox 5 - for vinyl jukeboxes
Product 15 of 17
Item #: V300
software to print titlestrips and archive your 45 and 78 rpm record colletion
We offer JukeBox by 'low Profile'. This software offers to print your titlestrips and to keep your record info in a database.
Features of "JukeBox" by low Profile
Titlestrips
  • Print strips for 45's or 78's.
  • Print on plain paper or preprinted strips.
  • Assign a different title strip image to each record. Use any bitmap graphic for background (several included).
  • Set fonts and alignment for title, artist and information line.
  • Two title lines for EP or long titles.
  • Subtitles and supertitles for a smaller size title text above or below the main song title.
  • Optional Quotes around title, information lines or Stars around artist name.
  • Choose just A or B side when printing 78 title strips.
  • Preview of each record's title strip.
  • Print Basket - put records in the Print Basket and print when you're ready. Records stay in the Print Basket until you empty it.
  • Use any printer you have set up for Windows.
  • Print multiples of one strip.
Record Data
  • Easy entry with dropdown lookups for artist, label, style and condition.
  • Two Artist names - a File Name for program use and a Title Strip Name.
  • Record number - Auto-increment option.
  • User defined new record default values for RPM, style, condition and custom fields.
  • Optional forcing of upper-case characters.
  • Assign records to a location or jukebox.
  • Side A and Side B info line.
  • Configure Info lines to automatically use up to 2 other fields or enter manually.
  • Find and Replace function for all fields.
  • 3 custom text fields, 2 custom numeric fields, 1 custom currency field, 2 custom date fields and 2 custom logical (True/False) fields.
  • Record grid shows all record information.
  • Customize the Record grid to your liking, including font, alternate background colors, row height and much more.
  • Create custom views - save and reuse definable subsets of your record inventory.
  • Search for records on all data fields.
  • Inventory valuation - calculates total value and cost.
  • Import from existing databases - the import database must be in the DBF format. Most database and spreadsheet programs can convert or export into this format.
  • Print lists of records - by artist, title and label.
  • Print Sleeve labels
  • Print all records for a single artist
  • Copy records
Improved Data Entry and Manipulation
  • Search and Replace function
  • New design for record grid
  • Sort on any column
  • Move columns
  • Adjust height of rows (1-4 lines)
  • Set colors of alternating rows
  • Grid settings saved automatically
  • Vertical slide bar proportional to position in database
Title Strip Printing Setup
  • Real print preview display for easier setup.
  • Save settings easily for reuse
Improved Report Generation
  • Design and print reports of your record inventory
On-Screen Help Files
  • Context sensitive by screen.
Wish List
  • Keep artist and titles of records you are looking for. Easily transfer to inventory when you get the record.
Back-Up Data
  • Save all data to floppy diskettes, ZIP drives or hard drive for safekeeping
JukeBox Data
  • Maintain all pertinent information about your jukebox or jukebox collection
Customer Support
  • Email technical support by lowProfile for registered users.
Click here to see more detailed screenshots of JukeBox
Operating Systems: Windows 7, Windows 8, Windows 8.1, and Windows 10.
We recommend the following related products:
Reviews
Markus writes: 28.10.2019
Super hab alle Titelstreifen damit geschrieben.
* incl. tax, plus shipping
