Attention: Please read notes below regarding Brexit, shipping information and closing time.
Record cleaner
Product 10 of 18
Item #: RP200
for vinyl records; incl. microfibre cloth
200 ml spray bottle
Record cleaner which efficiently removes dust, dirt and static build-up. The specially formulated solution ensures proper every day cleaning at the same time being the most effective cleaning method for badly soiled records.
Users instructions: Spray the liquid on the grooves over the entire record in a thin even layer. Normaly it is recommended to apply 5-6 buffs on the record. Use the cloth to wipe off the fluid along the grooves. Do not spray on the label.
The record is now cleaned and eliminated from static, as well as the friction is considerably reduced between the stylus and the groove, so that less distortion is obtained.
Note: Do not use for 78 RPM shellac records.
Content: 200 ml pump spray
(100 ml = € 4,25)
Reviews
Rüdiger writes: 30.11.2019
Sehr zu empfehlen für die schnelle Reinigung!
* incl. tax, plus shipping
