Please see notes below.
Winyl Gel "Advanced Cleaning"
Product 9 of 16
Item #: RP201
cleaning gel for vinyl records, 500 ml
Cart deactivated
Dirt and dust which cause crunchy and crackling noises reduce the joy to listen to records and cause a faster wear of the needle. Winyl Gel offers a professional cleaning solution! It was developed and produced in cooperation of chemists and record collectors.
Winyl Gel makes a fine film which goes deep into the grooves and removes dirt and dust. Furthermore it takes away the troublesome static electricity accumulated on the surface. The film cleans the most difficult areas such as the groove sides, improving the low and high frequencies. The final result is a clear and faithful reproduction and a fine listening experience in High Fidelity.
Winyl Gel is composed for 2 synthetic polymers, non ionic surfactants, antistatic agents, wetting agents, cleaners, conserving agents and more to obtain the best results. All its components have been designed and tested to damage the vinyl surface - even after several cleaning procedures.
How it works: Winyl gel gets applied smoothly to the record, the label stays free of course. After a short while of drying the whole film can be removed. By doing so dirt and dust get removed as well and the record is completely clean.
The delivery includes next to the 500 ml gel two injections for exact dosage and an instruction sheet in English, French, Spanish, and German.
  Do not use on 78 rpm schellac records.
(100 ml = € 3,98)
Reviews
Rüdiger writes: 30.11.2019
Exzellentes Reinigungsmittel! Da wird "agbenudelten" Platten nochmal ein zweites Leben eingehaucht!
* incl. tax, plus shipping
