Attention: Please read notes below regarding Brexit, shipping information and closing time.
Winyl Pro-Clean-6
Product 8 of 18
Item #: RP202
cleaning concentrate for 45 and 78 rpm records
also good for Knosti and other washing devices
60 ml bottle yields up to 6 litres of cleaning fluid
Winyl Pro-Clean-6 is a cleaning concentrate which was developed and produced in cooperation of chemists and record collectors. Regarding the motto "Less is more" it is without usage of alcohol which makes it suitable for all kinds of records - no matter if schellac, vinyl, lacquer (acetates) or styrene.
Next to three non-ionic surfactants it contains distilled water only. Pro-Clean-6 does not contain any brightener agent, solvents, colorants, fragrance or any other aggressive compounds.
The 60 ml concentrate makes 6 litres of cleaning fluid mixed with distilled water.
Detailed characteristics:
  • Concentrate makes 6 litres of cleaning fluid with distilled water.
  • For Vinyl Records, Shellac (78 rpm), Lacquer (Acetates), Styrene (45s) and Edmon Diamond Disc.
  • Alcohol Free, no aggressive chemicals, no brighteners.
  • Removes a wide range of dirt, increasing bass response and improving soundstage clarity from LP playback.
  • For vacuum cleaning machines (RCM), Knosti type machines, manual washing & Ultrasounds cleaning.
  • It does not leave any residues into the groove and the stylus thanks to its high purity formula without unnecessary compounds.
  • Anti-static formula.
  • Non-Toxic, Biodegradable and environmentally friendly.
  • Cost-effective cleaning of hundreds of records.
  • Fluid formula, clear, colourless and odourless. Mixed with distilled water it does not get cloudy and particles do not separate.
The delivery includes next to 60 ml concentrate two injections for exact dosage and an instruction sheet in English, French, Spanish, and German.
(100 ml = € 48,17)
Reviews
Helmut writes: 17.03.2021
Habe fast alle Singls gereinigt bin sehr zufrieden.
Heinrich writes: 14.04.2020
Reinigungsflüssigkeit verwende ich mit Ultraschall-Reinigungsgerät bei drehenden Platten. Ergebnis ist sehr gut. Habe bereits 800 Singles mit der ersten Dose gereinigt und dere Rest reicht sicher noch für 200 Singles. Reinigt sauber. Bei Erstreinigung, teilweise dicke Fettflecke, müssen nachgereinigt werden.
* incl. tax, plus shipping
