AMI & Rowe/AMI im Archiv von Jukebox-World
R-82 Woodhue, Explorer & Black Magic (1978)
200 Wahlmöglichkeiten   –   200 selections
Designer: Melvin Herman Boldt, patent D256,357 - filed 1977
Woodhue
Black Magic
In Deutschland als "Explorer 200" angeboten
Offered in Germany as "Explorer 200"
Wahlen / Selections 200
Lampen / Lamps
Title Panel: TL 19W/26"/T8   |   Front door: TL 30W/36"/T8   |   Keyboard: 2x #755 (lamp #47 can be used instead)
Service lamp: E27 110V 40W
Verstärker / Amplifier
64 Watt Stereo: # 606-02179   |   Pre-Amp: # 602-03758
Potentiometer: 2x10 KΩ (stereo)
Netzteil / Power supply 120V: 401-06894
220V: 402-65079
Kreditgerät / Credit unit 601-07674
Computer
Selection Logic Assembly: # 601-08060   |   Memory Unit: 601-07666 resp. 301-07855
Selection Computer (Memorec): 4-07139
Mechanism Control Unit: 401-06905
Lautsprecher / Speaker Low: 10"   |   Mid/High stereo: 6"   |   Mid/High mono: 5.25"
Mechanismus / Mechanism # 601-03065
Tonabnehmer / Cartridge Shure M44
Sicherungen / Fuses Main Power Supply 110V: 2.5A, 1A, 3A slo-blo + 10A, 2A Circuit Breaker
Main Power Supply 220V: 2.5A, 1A, 3A slo-blo + 6A, 5A, 3A Circuit Breaker
Amplifier 64W: 1-1/2 A circuit breaker, 4x 3A slo
Amplifier 120W: 3A circuit breaker + 4x 5A MTH
Schlüssel / Key C033-A
Abmessungen / Size
H 142  x B 106 x T 66 cm / H 56 x W 41-7/8 x D 26"
145 kg / 320 lbs
Zubehör / Accessories
Automix   |    Wallbox Wallette WRD   |    Stepper CGA   |    Extra speaker EX 401, EX 201, EX 301
Background music adapter   |    Phono paging system   |    Money meter   |    Dollar bill acceptor   |    Monitor alarm kit
Besonderheiten / Features Two models R-82 could be conneted together that each selection made from any of these two models were played one after the other without a break. So called Disco-Connector, same like on R-83.
