Bilder AMI im Archiv von Jukebox-World
AMI G-40 (1955)   |   G-80 (1955)  |   G-120 (1955)  |   G-200 (1956)
Lizenz: National Instruments Pty. Ltd., Australien
AMI-History-Book: The "G" was available in the following colors:
Delft Blue, Cherry Red, Emberred Charcoal, Chartreuse Green, Bright Sand, Canary Yellow, Atoll Coral, and Night-Sky Black
Erste Vorstellung:
Modelle G40, G80 und G120: 25.9.1955
Modell G200: Mai 1956
  Also produced in license by National Instruments Pty. Ltd., Australia
First presentation:
Models G40, G80 and G120 on Sep 25, 1955
Model G200: May 1956
Designer
Cabinet: Melvin Hermann Boldt, patents D177,959, D178,167 - both filed 1955
Loudspeaker and wide angle low frequency horn: Charles Scott Brown, patent CH346369, filed 1956
40 selection mechanism:
Harry Herbert Vanderzee, Robert McCallum, patents US2,666,649, US2,697,607 - both filed 1946
80 / 120 selection mechansim: Harry Herbert Vanderzee, George S. Brown, Franklyn Nickl, William Kuntz, patent CA613507
200 selection mechanism:
Harry Herbert Vanderzee, George S. Brown, patent 2,952,463 - filed 1954
Annunciator G80 and G120: William Kuntz, patent US2810582 - filed 1954
AMI G-40 - 1955
AMI G 40
Technische Daten - Specifications G-40
Wahlen / Selections
40 – 78 RPM; Mechanism could be converted to 45 rpm
Lampen / Lamps
Top Light: 20W/24"/T12    |   Grill: 15W/18"/T8     |     Coin chute: 7C7W frosted 7W     |     Credit: GE #47
Verstärker / Amplifier
R-144 (mono): Valves 12AX7, 12AU7, 2x 6L6, 5U4
Netzteil / Power supply
L 519
Kreditgerät / Credit unit
Lautsprecher / Speaker
Mechanismus / Mechanism
R-220
Tonabnehmer / Cartridge
Up to serial number 300186: GE RPX-040 / GE RPX-046       |     Serial number 300187 and up: GE RPJ-RPX
Sicherungen / Fuses
Amplifier: 1x 2A quick blo   |   Junction box: 8A quick blo, 2x 800 mA slo blo
Schlüssel / Key
50A-1
Abmessungen / Size
H 61-1/4" x W 32-3/8" x D 26-5/16"; 277 lbs
Zubehör / Accessories
Wallbox W40   |   Stepper S40   |   Remote control H-338   |   Extra Speaker EX 100, EX-200, EX-300
Besonderheiten / Features
Cabinet available in eight colour versions: Delft Blue, Cherry Red, Emberred Charcoal, Chartreuse Green, Bright Sand, Canary Yellow, Atoll Coral, and Night-Sky Black
AMI G80 - 1955
Bilder: Adi Gavoldi
AMI G 80 AMI G 80
AMI G 80
Australian version G-80 produced by National Instruments Pty. Ltd., Australia
Photos by courtesy of Ken Reed
AMI National Instruments G 80
Amplifier RA-145:
This was made for Australian mains voltage, the selector at front left can be set to either 230, 240 or 250v AC. The National AMI Logo can be seen at right. The Phono input socket was not an RCA plug but a plug type I have not seen before - it is much the same size as the base of a bayonet fitting #44 pinball bulb and connects to the amplifier socket exactly the same way as the #44 bulb would go into a socket.
AMI National Instruments G 80 RA-145
More information about AUS electrical devices
Technische Daten - Specifications G-80
Wahlen / Selections
80 – 45 rpm
Lampen / Lamps
USA: R-145 with
12AX7, 2x 12AU7, 2x 6L6; 5U4; Pot: 35 KΩ
Australia: RA-145 (mono) - made for 230 - 250 VAC
12AX7, 2x 12AU7; 2x 6L6; 5U4; Pot: 35 KΩ
Lautstärkeregler / Volume Control H338
L 519
700
GE RPJ-RPX
Sicherungen / Fuses
Schlüssel / Key
50A-1
Abmessungen / Size
H 61-1/4" x W 32-3/8" x D 26-5/16"; 306 lbs
Wallbox W120   |   Stepper S80   |   Remote control H-338
#326825 and up: With amplifier R-145 with changes regarding the AVC H-486 - compare Service Bulletin #134, dated Nov. 20 1956
Available in eight colour versions: Delft Blue, Cherry Red, Emberred Charcoal, Chartreuse Green, Bright Sand, Canary Yellow, Atoll Coral, and Night-Sky Black
G120 - 1955
Bilder: Adi Gavoldi
AMI G 120 AMI G 120
Picture: Thor Haugen
AMI G 120
Technische Daten - Specifications G-120
Wahlen / Selections
120 – 45 rpm
Lampen / Lamps
Top Light: 25W/33"/T12     |     Grill: 15W/18"/T8     |     Coin chute: 7C7W frosted 7W     |     Credit: GE #47
R-145 (mono): 12AX7, 2x 12AU7, 2x 6L6, 5U4; Pot: 35 KΩ
L 519
800
GE RPJ-RPX
Sicherungen / Fuses
Schlüssel / Key
50A-1
Abmessungen / Size
H 62-1/2" x W 36-9/816 x D 26-5/16"; 330 lbs
Wallbox W120   |   Stepper S120   |   Remote control H-338
G200 - 1956
Vorgestellt Mai 1956
Erste AMI mit Plattenkarussell
in Lizenz gebaut durch
Introduced in May 1956
First AMI with a rotating record magazin.
AMI G200 Musikbox Jukebox G200
Melvin Herman Boldt
Courtesy Gert Almind
AMI G200 120 80 40 Melvin Boldt
Charles Scott Brown
AMI G200 120 80 40 Charles Scott Brown
Wahlen / Selections 200 – 45 rpm
Lampen / Lamps Credit: 2x GE #47     |     Coin chute: 7C7W frosted 7W     |     cabinet: 20W/T12/24"; 4W/T5/6"; 15W/T8/18"
Verstärker / Amplifier R-145 (mono): 12AX7, 2x 12AU7, 2x 6L6, 5U4; Pot: 35 KΩ
Netzteil / Power supply L 1249
Mechanismus / Mechanism 900
Tonabnehmer / Cartridge GE VRII
Sicherungen / Fuses Amplifier: 1x 2A     |     Junction box: 8A (fl.), 1A, 1x 2A, 0.8A
Schlüssel / Key RI-303
Abmessungen / Size
Zubehör / Accessories Wallbox WQ200 / WQ120; remote control H-338
Extra Speaker EX 100, EX-200; EX-300; Automix-Kit 45-33: R-2047A;
Designer Mechanism H.H. Vanderzee - patent 292463 - filed 1954 - "Record Selecting Mechanism"
Stepper built-in (pulse generator)
#350450 and up
With four credit magnets in the credit unit. Compare Service Bulletin #120, dated April 20, 1956.
#352325 and up
With an add. 2A fuse (slo-blo) which has been installed in junction box to protect transformer from damage in cases where the rectifier should become internally shorted.
#354771 and up
With new plastic cash box (L-1271) to replace H-1242.
#356400 and up
With amplifier R-145 with changes regarding the AVC H-486. Compare Service Bulletin #134, dated Nov. 20 1956
#357168 and up
With pulse converter employing a gear drive between the selector drive motor and the sprag wheel.
