AMI & Rowe/AMI im Archiv von Jukebox-World
R-83: Claremont   •••   Fiesta   •••   Disco (1979)
200 Wahlmöglichkeiten   –   200 selections
Designer: Melvin Herman Boldt, patent D260,765 - filed 1978
R-83 Claremont
R-83 Disco
Rowe/AMI R-83 Claremont
Rowe/AMI R-83 Disco
R-83 Fiesta
Photo courtesy of Lynn C.
Rowe/AMI R-83 Fiesta
Wahlen / Selections 200
Lampen / Lamps
Title Panel and crest: 2x TL 19W/26"/T8   |   Front door: TL 30W/36"/T8   |   Keyboard: 2x #755 (lamp #47 can be used instead)
Service lamp: E27 110V 40W
Verstärker / Amplifier 125 Watt Stereo: # 601-07438   |   125 Watt Pre-Amp: # 601-08552
Potentiometer: 2x10 KΩ (stereo)
Netzteil / Power supply 120V: 401-06894
220V: 402-65079
Kreditgerät / Credit unit 601-07674
Computer
Selection Logic Assembly: # 601-08060   |   Memory Unit: 601-07666 resp. 301-07855
Selection Computer (Memorec): 4-07139
Mechanism Control Unit: 401-06905
Lautsprecher / Speaker Low: 10"   |   Mid/High stereo: 6"   |   Mid/High mono: 5.25"
Mechanismus / Mechanism # 601-03065-04
Tonabnehmer / Cartridge Shure M44
Sicherungen / Fuses Main Power Supply 110V: 2.5A, 1A, 3A slo-blo + 10A, 2A, 3A Circuit Breaker
Main Power Supply 220V: 2.5A, 1A, 3A slo-blo + 6A, 5A, 3A Circuit Breaker
Amplifier: 3A circuit breaker + 5A MTH
Schlüssel / Key C033-A (?)
Abmessungen / Size
H 142  x B 106 x T 66 cm / H 56 x W 41-7/8 x D 26"
145 kg / 320 lbs
Zubehör / Accessories
Automix   |    Wallbox Wallette WRD   |    Stepper CGA   |    Extra speaker EX 201, EX 305   |    Background music adapter
Phono paging system   |    Money meter   |    Dollar bill acceptor   |    Monitor alarm kit
Besonderheiten / Features
Model Disco 200 with special light and colour effects: a special so called "Disco-Coupler" was available. Two Disco 200 models could be conneted together that each selection made from any of these two models were played one after the other without a break.
