| Rock-Ola Series F |
Rock-Ola 1422 (1946) |
| 1422 |
| Technische Daten - Specifications Rock-Ola 1422 | |
| Wahlen / Selections | 20 |
| Mechanismus / Mechanism | Smyth |
| Gehäuse / Cabinet | |
| Lampen / Lamps |
Upper
cabinet: TL 15W/18"/T12 Large pilaster: 2x TL 20W/24"/T12 Short pilaster: E27 7,5W/110 V; 25W/110V "Thank you": Ba9s 28V 4,8W |
| Verstärker / Amplifier |
Model O - 12238-A: 2x 6L6; 1x 6J5; 1x 5U4 pot: dual volume
control 2 Meg 50 M Ohm Model OS: add. 6SN7 in voltage amplifier stage - coupled to power amp. stage |
| Netzteil / Power Supply | 12242-A |
| Kreditgerät / Credit Unit | 12220-A |
| Kontollbox / Control Box | |
| Lautsprecher / Speaker | Dynamic speaker, voice coil 8 Ohm, field coil 5000 Ohm |
| Tonabnehmer / Cartridge |
Astatic L-21
ceramic Often replaced by Astatic 4, 12 or 12U (crystal) or later with Astatic 51-2 |
| Sicherungen / Fuses | Power Supply 3A, 6A, 10A; amplifier 3A |
| Schlüssel / Key | D032 |
| Abmessungen / Size | B x H x T = 29 3/4 x 58 x 26" |
| Zubehör / Accessories |
Extra
speaker:
1603,
1807 Moderne,
1606 Tonette, Super Tonette, Tone-O-Lier Wall Box Bar Bracket 1531, Universal Bar Bracket 1533, Wall Box Line Booster 11795 Remote Vol. Control 1906; wallbox 1530 |
Photo courtesy of
Coinopwarehouse |
| Technische Daten - Specifications Rock-Ola 1426 | |||||
| 1426 | 1426A | 1426E | 1426R |
1426RA |
| Wahlen / Selections | 20 | 20 | 20 | 20 | 20 |
| Mechanismus / Mechanism | Smyth | Smyth | Smyth | Smyth | Smyth |
| Gehäuse / Cabinet | Dark | Dark |
Blonde |
| Lampen / Lamps |
Pilaster: TL 20W/24"/T12 Upper cabinet: TL15W/18"/T12 "Thank you" lamp: Ba9s 28V 4,8W |
Model O - 12238-A: 2x 6L6; 1x 6J5; 1x 5U4 Pot: Dual volume control 2 Meg 50 M Ohm Model OS: Add. 6SN7 in voltage amplifier stage - coupled to power amp. stage |
| Netzteil / Power Supply | 12242-A | 12242-A | 12242-A | 12242-A | 12242-A |
| Kontollbox / Control Box | |||||
| Lautsprecher / Speaker | Dynamic speaker, voice coil 8 Ohm, field coil 5000 Ohm | Dynamic speaker, voice coil 8 Ohm, field coil 5000 Ohm | Dynamic speaker, voice coil 8 Ohm, field coil 5000 Ohm | Dynamic speaker, voice coil 8 Ohm, field coil 5000 Ohm | Dynamic speaker, voice coil 8 Ohm, field coil 5000 Ohm |
Astatic L-21
Astatic L-21
Astatic L-21
Astatic L-21
Astatic L-21
Power Supply 3A, 6A, 10A Amplifier 3A |
| Schlüssel / Key | D032 | D032 | D032 | D032 | D032 |
| Abmessungen / Size | |||||
Extra
speaker: 1603, 1807 Moderne, 1606 Tonette, Super Tonette, Tone-O-Lier Wall Box Bar Bracket 1531, Universal Bar Bracket 1533, Wall Box Line Booster 11795 Remote Vol. Control 1906 Wallbox 1530 |
Extra
Extra
Extra
Extra
| Besonderheiten / Features | |||||
1424 Play Master |
| Technische Daten - Specifications Rock-Ola 1424 | |
| Lautsprecher / Speaker | Ddynamic speaker, voice coil 8 Ohm, field coil 5000 Ohm |
Astatic L-21
| Schlüssel / Key | |
Extra speaker:
1603,
1807 Moderne,
1606 Tonette, Super Tonette, Tone-O-Lier wallbox 1530, 1536; Wall Box Bar Bracket 1531, Universal Bar Bracket 1533, Wall Box Line Booster 11795 Remote Vol. Control 1906 |
Verstärker Modell O – amplifier type O |
Fotos: Dirk Schirner
