AMI & Rowe/AMI Musikboxen im Archiv von Jukebox-World |
| Rowe/AMI ••• Microtecnica |
Rowe/AMI JAL & JEL (1962-63)
Cabinet Designer:
Melvin Herman Boldt, patent
D197,089
- filed 1962 |
Rowe/AMI JAL&JEL (1962-63)
Microtechnica AMI JCL-200 Mechanism convertable from 200 to 100 and 160 selections Introduced in 5/1962
Lizenzen in anderen Ländern / License holder in other countries: |
| JAL | ||||
| JEL (LB200) | ||||
| Titelanzeige: Anpassung von 200 an 160 oder 100 Wahlen - Title board: Conversion from 200 to 160 or 100 selections only | ||||
| Control Amplifier R-2622C | ||||
2x 12 AX7; 2x 6AW8A, 2x 12AU7,
2x 7025/ECC83![]() |
| JCL-200 | ||||
Manual selection - mechanism: 960, amplifier R-2776,
R 2020, cabinet in different colours Made by Microtecnica Torino under license AMI (international) S.A. Panama R.P.
| JAL | JEL | JCL | |
| Wahlen / Selections | 200 | 200 | 200 |
| Gehäuse / Cabinet |
Available in brown or black paint or wood grain decal Front with "Stereo Round" and "Rowe AMI" available in black and red The vertical bar at grill is not aligned with grill |
Two colour sides |
Available in black paint or wood grain Front with "Stereo Round" and "AMI" only available in black and blue and brown
| Lampen / Lamps |
25W/28"/T12 2x 6W, 2x 8W, 1x 15W |
| Verstärker / Amplifier |
Power Amp R-2620:
2x 12AX7, 5U4GB, 4x 7868; Control Amp R 2622: 2x 12 AX7, 2x 6AW8A, 2x 12AU7, 2x 7025/ECC83 |
Power Amp R-2620:
Basic Amplifier R-2777: 5U4GB, 2x 12AU7, 2x 6973 Add-On Power L-2728: 2x 12AU7, 2x 6973 Stereo Control R 2020: 2x 12AX7, 2x 7025/ECC83 |
| Netzteil / Power supply | L 2526 | L 2526 | |
| Kreditgerät / Credit unit | R-1473B | R-1473B | |
| Lautsprecher / Speaker |
12" 16 Ohm Low Freq. 6"x9" 4 Ohm Mid Range (2) |
| Mechanismus / Mechanism | 1100 | 1100 | 960 |
| Tonabnehmer / Cartridge | Shure M-77DA with stylus Shure N77 | Shure M-77DA with stylus Shure N77 | GE VR22 |
| Sicherungen / Fuses |
Selector: 2A, 600 mA slo blo; Junction Box: 8A fl., 2A, 3.2 A Fustat |
| Schlüssel / Key | C-440A | C-440A | |
| Abmessungen / Size | 145 x 85 x 68 cm; 188 kg | 145 x 85 x 68 cm; 188 kg | |
| Zubehör / Accessories |
CDA: For use with any wallbox CDD: For use with Seeburg 100 selection wallbox Wallbox WQ200 Remote volume control H 3037E |
No stepper nor wallbox |
| Neupreis 1963 / Original price | Pricelist Nordwestdt. Autom GmbH & Co. 06/1963: 6450 DM | ||
| Besonderheiten / Features |
First Rowe/AMI model Mechanism could be converted from 200 to 100 and 160 selections; Automix as standard feature |
Model JCL only available by Microtechnica, Italy Manual selection jukebox with technical equipment from previous models |
