Seeburg Jukeboxes & Wallboxes im Archiv von Jukebox-World |
| Seeburg 8200: 8200, 8200A, RC8200, RC8200A, RCT8200, RCT8200A, 8200 SLMS, 8200SLMS modified (1942) |
20 selections, 78 RPM Designer: Cabinet: Henry T. Roberts, patent D130,048, filed 1940 Cabinet illumination: Nels A. Miller, patent 2,297,907, filed 1941 Basic Mechanism: Carl Gunnar Freborg, patents 2,243,689, filed 1937 and 2,266,495, filed 1938 and US2,237,139 - filed 1940 Charles August Freborg, patents 2,243,689, filed 1937 and 2,266,495, filed 1938 Credit and selection mechanism: Russell Ira Wilcox, patent 2,215,141 - filed 1937 |
Seeburg 8200 SLMS (1942) - manual select |
The 8200M is made from birch and maple woods and used the Seeburg “Marbl-glo” process (picture upper right). The designs in the wood were “airbrushed” with a compressor -- by hand, so no two machines had the same exact pattern. After airbrushing, a sealant was placed on top of it all to bond it to the wood permanently. So the end result looks like granite or polished stone.
When the
machine is lit in a dark room, it looks like a magnigicent “fountain of
light” and is just mesmerizing to watch. The pilasters are made from fluted
glass tiles and the top vertical glass and the dome glass is fluted all
around. A huge 15” speaker sits with its cone facing upwards towards the top
and baffles inside deflect the sound out both sides and the front. In
addition, an 8” speaker made by Utah Corporation is housed behind the center
grill cloth and used for added sound output. The amp is a model 720E
(nobody’s ever heard of it) but it is an authentic Seeburg amp and has all
the ID plates as such. Pictures and info:
Edward M. Liss |
Seeburg 8200A (1942) |
Photos courtesy
Lloyd Thoburn
Picture below: Note the side pilasters are solid
glass instead of the usual blocks |
Seeburg 8200 LoTone (1942) |
Photo courtesy Jörg W. |
Seeburg 8200 SLMS - modified |
Pictures courtesy of Robin,
information
Edward M. Liss
Henry Thomas Roberts |
Courtesy Gert Almind |
| 8200 | 8200RC | |
| Wahlen / Selections | 20 | 20 |
| Lampen / Lamps |
Lower Pilaster, Service, Sides: GE #81 (33) Dome Light: GE #87 (2) |
| Verstärker / Amplifier |
825-10A: 6SQ7, 6J5GT (3), 6L6 (2),
5U4G, 5Y3G 720E |
MCS25-15A: 6SQ7, 6J5GT (3), 6L6 (2), 6SK7 (2), 6H6, 6X5GT, 2051, 5U4, 5Y3G |
| Mechanismus / Mechanism | Freborg | Freborg |
| Electrical Selector | ES5-Z | ES5-Z |
| Solenoid Drum | SD20-7Z | SD20-7Z |
| Kreditgerät / Credit Unit | RB-6Z | RB-6Z |
| Lautsprecher / Speaker | 15" Electrodynamic Jensen | 15" Electrodynamic Jensen |
| Tonabnehmer / Cartridge | ||
| Sicherungen / Fuses |
Amplifier: 1.5A, 2.5A Power supply: 1.5A; 1.8A; 2.5A (2) Solenoid Fuse: 0.5A |
| Schlüssel / Key | Front and Back door: C1440 | Front and Back door: C1440 |
| Abmessungen / Size | ||
| Zubehör / Accessories | Remote
Selection Cancel Kit C-5Z Receiver: Selection Receiver SR-4, Remote Receiver RR6-2Z PS6-1Z, PS12-3Z Power Supply Step selector SS20-1 | Wired Adaptor WA-1Z Transmitter T-3Z for remote sound system Extra Speaker Marbl-Glo, Top Spot, SpeakOrgans Wallboxes: WS-2Z, WS-10Z, WB-5Z, WB-1Z, DS20-1Z, DS20-10Z, DSB-1Z |
Remote
Volume and Selection Cancel Kit VC-1Z Transmitter T-3Z for remote sound system Wallboxes: WS-2Z, WS-10Z, WB-5Z, WB-1Z, DS20-1Z, DS20-10Z, DSB-1Z Extra Speaker Marbl-Glo, Top Spot, SpeakOrgans |
| Besonderheiten / Features | Uses glass blocks instead of catalin plastics | Uses glass blocks instead of catalin plastics |
| Die Angaben haben
