AMI und AMI/Rowe Musikboxen im Archiv von Jukebox-World |
| ROWE/AMI MM-3 "Music Miracle" (1969) - Das Klangwunder |
Auch als Lizenzbau von
National Instruments Pty. Ltd, Australia Vertrieb Europa: Amiro SA, Schweiz Besonderheiten:
Designer cabinet: Melvin Hermann Boldt, patent D215,760 - filed 1968 |
Also built under license
by National Instruments Pty. Ltd, Australia Distribution Europe: Amiro SA, Switzerland Special Features:
MM3 - Music Miracle |
Version: Moonburst
Change-A-Scene
Mit "Wall of Sound" Anbau-Lautsprecher ---
With "Wall of Sound" side speakers |
Australian version MM3 produced by National Instruments Pty. Ltd., Australia |
Photo by courtesy of
Ken Reed |
| Wahlen / Selections | 200 |
| Lampen / Lamps | Keyboard: 18W/T8/24" | Door: 2x 25W/T12/33" | Record indicator lamps 5x GE #47 |
| Verstärker / Amplifier | 50W: # 3812 / Pre-Amp: #
3758 or 100W: R-3760A / Pre-Amp: # 3758 Australian version: Solid state amp 240 V - 25W mono amp as an option |
| Netzteil / Power supply | #401-05767 |
| Lautsprecher / Speaker | Model 1100: # 603-03300 |
| Kreditgerät / Credit unit | 1x 12", 19 Ohm and 2x 6", 16 Ohm |
| Mechanismus / Mechanism | # 606-03050 |
| Tonabnehmer / Cartridge | Shure M44 |
| Sicherungen / Fuses | 50W Amp: GMQ 2A; MDL 1.5A;
100W Amp: GMQ 3.2A; MDL 2A Credit Unit: 600 mA; Junction Box: 6.25A; 8A MDL; 2x 800 mA |
| Schlüssel / Key | C-440A |
| Abmessungen / Size | 55-5/8" x 42" x 26-5/8"; 372 lbs |
| Zubehör / Accessories | Extra speaker EX 401, EX
600, EX 700, SGF |
"Wall-of-Sound" side speakers Phono Vue | Wallbox Wall-Ette WRC | MAB Money Counter | Wallbox Counter Bracket 201-12796 Stepper CGA for Rowe/AMI wallbox | Stepper CGC for competitive 200 and 160 wallbox | Stepper CGD for Seeburg 3W1/3W100 Stepper CGE for Seeburg Consolette | Play-Me Feature |
| Besonderheiten / Features | Factory made for 200
selection but could be converted 1. Conversion Kit: contains decorative and display parts for 100 and 160 selection conversion 2. Counterweight assembly: Adapts phonograph record changer mechanism for 100 and 160 selections. One is required for every five records replaced. Front panel in three Change-A-Scene versions: "Moonburst", "Spinning Wheels" and "Flower Girl" Also availabble as "Wall-Of-Sound" with wedge shaped speakers attached to each side |
