AMI & Rowe/AMI im Archiv von Jukebox-World
AMI K (1960)
JAK200  •  JBK-120  •   JCK-100  •   JDK-200  •  JEK-200  •  JFK-120  •  JGK-100  •  JHK-200  •  JJK-200  •  JKK-200  •  JLK-100
JNK-100  •  JPK-200
Cabinet Designer: Melvin Herman Boldt, patent D188,769 - filed 1958
Vorgestellt 11/1959
auch als Lizenzbau durch
AMI Sinfonolas Mexico S.A.
- National Instruments Pty. Ltd, Australia: JDK-200 und JJK-200
 Introduced in 11/1959
Also built under license by
National Instruments Pty. Ltd, Australia: JDK-200 and JJK-200
Modelltypen - Model Types
Model Equipment Mechanism Amplifier Also called Notes
JAK-200 Electrical Selection System 900 Mono K200 Stepper (pulse converter) built-in for wallbox use
JBK-120 Electrical Selection System 900-1 Mono K120 Stepper (pulse converter) built-in for wallbox use
JCK-100 Manual Selection System 950 Mono K100M no use of wallbox possible
JDK-200 Manual Selection System 960 Mono K200M no use of wallbox possible
JEK-200 Electrical Selection System 900 Stereo K200 Stepper (pulse converter) built-in for wallbox use
JFK-120 Electrical Selection System 950 Stereo K120 Stepper (pulse converter) built-in for wallbox use
JGK-100 Manual Selection System 950 Stereo K100M no use of wallbox possible
JHK-200 Manual Selection System 960 Stereo K200M no use of wallbox possible
JJK-200 Automatic Selection System 985 Mono K200A Extra stepper needed for wallbox use
JKK-200 Automatic Selection System 985 Stereo K200A Extra stepper needed for wallbox use
JLK-100 Automatic Selection System 990 Mono K100A Extra stepper needed for wallbox use
JNK-100 Automatic Selection System 990 Stereo K100A Extra stepper needed for wallbox use
JPK-200 Automatic Selection System 995 Mono
So called "Halfback":
100 selections (A – K, 1 – 0) are placed common
100 titles play randomly as a background music system
Probably available in two versions
JAK-200: Electrical Selection System, mono
JDK-200: Manual Selection System, mono
AMI K200
AMI K200M
JLK-100: Automatic Selection System, mono
Photos courtesy Paul Zubec
AMI K100 Jukebox Musikbox
AMI K100 Jukebox Musikbox AMI K100 Jukebox Musikbox
JPK-200: Background Music Unit, mono; so called "Halfback"; first introduced in May 1960
There might have been different versions available of model JPK.
1. Version:
  • Random play feature
  • Amplifier: R2017 with L2156
  • Speaker: one low range and one horn
  • Front glass: "AMI", "The World's Finest Music"
  • Keyboard: 100 selections but holds 100 records
  • Keylock "mode" switch in back:
    when repositioned all of the machine lights shut off and play the other 50 records in series
  • Two counters: one for normal, one for "background" play
  • Automatic selector with seven wire bundle connectors – related to the "background" music mode.
AMI JPK-200
2. Version:
  • Amplifier: R2017-A with L2156-B
  • Date on certain parts: 30. Juni 1965
  • Keyboard for 200 selections (A – K / 1 – 20)
  • Front glass: "AMI" and "The World's Finest Music"
  • Mechanism: 995
AMI JPK-200 Mechanism 995
AMI JPK-200
3. Version: Made of a manual selection AMI K? Photos courtesy of www.radioamfilochia.gr
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
AMI JPK-200
Zuordnung der Mechanismen – order of mechanisms
Zuordnung Verstärker – order of amplifier
Technische Daten – Specifications
Wahlen / Selections 100 / 120 / 200
Lampen / Lamps Dome: 15W/T8/18"   |   Cabinet: 2x 20W/T12/24"   |   Credit lamps: 4x GE #47
Verstärker / Amplifier R-145: 12AX7; 2x 12AU7; 2x 6L6; 5U4; Pot: 35 KΩ
or
Multi-Use Amplifier:
Basic Amplifier R-2017/R-2017A: 5U4GB, 2x 12AU7, 2x 6973; Poti: 2x 5 KΩ
Add-On Control L-2156 (mono): 2x 12AX7, 12AU7, 7025/ECC83
Add-On Power L-2155: 2x 12AU7, 2x 6973
Stereo Control Amp R 2020: 4x 12AX7, 2x 12AU7, 2x 7025/ECC83
Lautstärkeregler / Volume Control Mono: H3059   |   Stereo: H3060
Netzteil / Power supply L2209-A
Kreditgerät / Credit unit R-1473
Lautsprecher / Speaker
Mechanismus / Mechanism 900, 900-1, 950, 960, 985, 990, 995 – details
Tonabnehmer / Cartridge GE VRII (mono), GE VR 22 (stereo)
Australian Version: Elac MST-1 with stylus Elac SN2
Sicherungen / Fuses Junction Box: 8A MDL, 2A, 2x 1A slo blo   |   Basic Amp. R-2017: 3A   |   Transformer f. wallbox: Fustat 3,2A
JJK – JPK with Automatic Selector: 600 mA slo blo
Schlüssel / Key C-440A
Abmessungen / Size
Neupreis 1960 / Original price Letter to operators: JAK-200: 6650 DM
Letter to operators: JDK-200: 5950 DM
Letter to operators: JEK-200: 6950 DM
Letter to operators: JHK-200: 6350 DM
Zubehör / Accessories JAK – JHK: Built in stepper   |   JJK – JNK: CCA (200) / CCB (100) Wallbox WQ200 / WQ120
Extra Speaker EX 400, EX 600, L-2130 available with various baffles: L-2605, L2170L2159, L-2158, L-2137, L-2136, L-2135 Automix-Kit 45-33: R-2047A   |   Remote control H-3037 / H-3333 (Amplifier R-145)
50c Bonus Play PH-25
Besonderheiten / Features
Pulse Generator   •   Selection Button Bank
Pulse Generator
used in JAK-200, JBK-120, JEK-200, JFK-120
by courtesy of Warwick
AMI K200
Selection Button Bank used in JJK-200 and JKK-200  ► no more stepper used in models JJK-200 and up
by courtesy of Graeme
AMI K200
New build AMI K cabinet
Pictures and info by Warwick
The K cabinet is a really well constructed and strong unit but was not meant to ever be taken apart as each panel was glued and screwed together and a lot of ripping of veneers occurs during the demolition. This is made harder because all of the panels interlock and grow from the base.
The one major problem with taking it apart was trying to work out how it was put together in the first place. This was not evident because as each panel was put on, it was then covered by another board or panel that was glued and screwed over the proceeding panel thus hiding all of the preceeding screws. You can be assured at some stages I wondered whether I should have taken it on as I found it frustrating at times and wondering whether the boards I made were going to fit and have the correct alignments at the end. Before I finally put it together I screwed the parts together, measured the result and only took it apart and finally glued it when I was reasonably sure it was ok.
AMI K200 AMI K200
Old cabinet – destroyed by humidity and insects
AMI K200
AMI K200
AMI K200
Photos courtesy of Tony Holmes and John S.
Before the restoration; all instructions had been screen-printed in Spanish
AMI K200 Mexico Phonograph Sinfonola AMI K200 Mexico Phonograph Sinfonola AMI K200 Mexico Phonograph Sinfonola
After the restoration:
