Jukebox-World Jukeboxen Jukeboxes Jukeboxparts Jukebox parts Archiv
Jukebox-World
AMI – Rowe/AMI Jukebox
       |      Stepper
HT = Hochtöner (tweeter)     |     LF = Tieftöner (low frequency)     |     Amp = Amplifier     |     Pot - Potentiometer
1" = 1 Inch = 2,541 cm     |     SN = Seriennummer (serial number)
Musikboxen - Jukeboxes
Modell - Model
Modéle
Lautsprecher - Speaker
Haut parleur
Verstärker + Potentiometer
Amplifier + Potentiometer
Amplificateur + potentiomètre
Netzteil - Power supply
Allimentation
FR 36S
FR Unknown 36
Streamliner
Top Flight   39C by Audio Protector Company, Grand Rapids, Michigan
Singing Tower   42: 6SC7, 2x 6J5, 2x 6L6, 5U4
Singing Tower
HB 302
Electro Dynamic
Speaker Series 40
C12R, #C62663 APS-110
40M
A   AA (ID amplifier) / L-20 (parts list; silver) SN: 1-14999:
6SJ7; 6SL7GT, 2x 6L6; 5U4G
Potentiometer: 1 MOhm, 1/2 Watt
BB (ID amplifier) / R-22 (parts list; black) SN: 15000 & up:
6SJ7; 6SN7GT, 2x 6L6G; 5U4G
Potentiometer: 500k, 1/2 Watt
B   BB (ID amplifier) / R-22 (parts list; black):
SN: 15000 and up
C CC (ID amplifier):
1. Version: 2x 6L6, 6SN7, 6N7GT, 6SA7, 5U4G,
2. Version: 2x 6L6, 6SN7, 6N7GT, 6SA7, 5U4G, 6H6
Pot: 25 KΩ
D 40 15" Permanent Magnet;
Coil: 16 Ohm
DD (ID amplifier) / R-111/R-113 (parts list):
2x 6L6, 2x 6SN7, 5U4G
Pot 50 KΩ
D 80 Junction Box R-13
E 40 15" Permanent Magnet;
Coil: 16 Ohm
R111: 5U4G, 2x 6SN7GT, 2x 6L6; Pot 35k
R105: 5U4G, 2x 6SN7GT, 2x 6L6; Pot 35k
E 80 15" Permanent Magnet;
Coil: 16 Ohm
E 120 15" Perm. Magnet;
Coil: 16 Ohm
F-40 Low-Frequency Driver
High Frequency Horn
R-144: 12AX7; 2x 12AU7; 2x 6L6; 5U4; Pot: 35 KΩ
F-80
F-120
High Frequency Horn
R-145: 12AX7; 2x 12AU7; 2x 6L6; 5U4; Pot: 35 KΩ
G-40   R-144: 12AX7; 2x 12AU7; 2x 6L6; 5U4; Pot: 35 KΩ L 519
G-80   R-145 (US): 5U4, 12AX7,
2x 12AU7; 2x 6L6
Pot: 35 KΩ
RA-145 (AUS): 5U4, 12AX7, 2x 12AU7; 2x 6L6
Pot: 35 KΩ
L 519
G-120   R-145: 12AX7; 2x 12AU7; 2x 6L6; 5U4; Pot: 35 KΩ L 519
G-200   R-145: 12AX7; 2x 12AU7; 2x 6L6; 5U4; Pot: 35 KΩ L 1249
H-100
H-120
H-200
Low Frequency 16 Ohm
High Frequency Horn
R-145: 12AX7; 2x 12AU7; 2x 6L6; 5U4; Pot: 35 KΩ L 1336
I-100
I-120
I-200
High Frequency Horn
2x R-145 for stereo set up
L 1336
J-100
J-120
J-200
L 1336
K-100
K-120
K-200
oder
Multi-Use-Amplifier:
Basic Amplifier R-2017/R-2017A:
5U4GB, 2x 12AU7, 2x 6973
Pot: 2x 5 KΩ (stereo) resp. 1x 5kOhm (mono)
Add-On Control L-2156 (mono):
2x 12AX7, 12AU7, 7025/ECC83
Add-On Power L-2155:
2x 12AU7, 2x 6973
Stereo Control Amp R-2020: 4x 12AX7, 2x 12AU7, 2x 7025/ECC83
L2209-A
Lyric   Multi-Use-Amplifier:
Basic Amplifier R-2017B:
2x 12AU7, 2x 6973
L2209-A
Conti 1   L2209-A
Lyric 2
Multi-Use-Amplifier USA:
Basic Amplifier R-2777:
1x 5kOhm (mono)
Add-On Control L-2156A (mono): 2x 12AX7, 12AU7, 7025/ECC83
Add-On Power L-2728A:
2x 12AU7, 2x 6973
Stereo Control R-2020:
4x 12AX7, 2x 12AU7
2x 7025/ECC83
Multi-Use-Amplifier Italian:
2x 12AU7, 2x 6973
2x 12AX7, 2x 7025/ECC83
Conti 2
Side: Ceramic 6"x9"
1 HT 3,5" - AlNiCo
1 LF 12" 16 Ohm AlNiCo
L2209-A
JAL
JEL
12" 16 Ohm Low Freq.
6"x9" 4 Ohm Mid Range (2)
Power Amp R-2620: 2x 12AX7, 5U4GB, 4x 7868
Control Amp R-2622:
2x 12 AX7; 2x 6AW8A, 2x 12AU7,
2x 7025/ECC83
L-2526
JCL (Microtecnica)   Multi-Use-Amplifier Italian by Microtecnica:
Basic Amplifier
R-2777: 5U4GB, 2x 12AU7, 2x 6973
Add-On Power
L-2728: 2x 12AU7, 2x 6973
Stereo Control R-2020: 2x 12AX7, 2x 7025/ECC83
JBM 12" Low Freq. AlNiCo
4"x6" High Freq.
6"x9" Mid Range (2)
USA - 110V:
Power Amp R-2620:
Control Amp R-2680:
12AT7, 2x 6AW8A, 2x 7025
Pot: 2x10 KΩ
AUS - 240V:
Power Amp R-2620A:
Control Amp R-2680A-B:  12AT7, 2x 6AW8A, 2x 7025
Pot: 2x10 KΩ
401-05218
JAN 12" Low Freq. Ceramic 16 Ohm Jensen C12PA
4"x6" High Freq.
6"x9" Mid Range (2)
Power Amp R-3390: 12AX7 (2), 5U4GB, 7868 (4)
Control Amp R-3389: 6AW8A (2), 12AT7, 12AX7A (2)
Pot: 2x10 KΩ
401-05382
JAO 12" Low Freq. Ceramic 16 Ohm Jensen C12PA
4"x6" High Freq.
6"x9" Mid Range (2)
401-05382
MM-1 12" Low Freq. ceramic
2x 6" mid/high freq. ceramic
Power Amp R-3680A: 4x 2N3055, 2N3054
Pot: 2x10 KΩ (stereo); 10 KΩ (mono)
403-05382
CMM-1 1x low 10" 32 Ohm
2x mid-high 6" 16 Ohm
Stereo Amplifier Ass. R-2576A:
Pre-Amplifier R-2574
Power Amplifier R-2575
Pot: 2x10 KΩ stereo
CMM-2 1x low 10" 32 Ohm
MM-2 2x Low: 10" 32 Ohm
2x Mid-High: 6" 16 Ohm
50 W Power # 3812 / Pre-Amp: # 3758
oder
100W: R-3760A / Pre-Amp: # 3758
401-05767
Fuses: 2x 800 mA, 6.25A, 8A
MM-3 1x Low: 12", 19 Ohm
oder
401-05767
MM-4 1x12", 15 Ohm
2x6", 16 Ohm
Röhrenamp 50W R-4359A: 5U4GB, 2x 12AX7, 4x 7868
401-05767
CMM-3 1x low 10" 32 Ohm
Solid State Mono R-2255
Preamp Solid State Mono: 2253
Power Amplifier Solid State: 2260
Hybrid Mono 25W R-4567
Power Amplifier Hybrid Mono: 4566A
1x 5U4GB, 1x 12AX7, 2x 7868
Preamp Hybrid Mono: 4570
Stereo 50W: R-4572
Power Amplifier stereo 50W: R-4359A
1x 5U4GB, 2x 12AX7, 4x 7868
Preamp 50W Stereo: R-4571
401-5767: 110V selenium rectifier
401-2453: 220V selenium rectifier
404-5767: 110V silicium diodes
404-2453: 220V silicium diodes
CMM-4 1x low 10" 32 Ohm
Stereo 50W: R-4572
MM-5 Low: 12", 15 Ohm
Mid: 6", 10 Ohm
Pre-Amp: R-4372
Transistor 100W
: R-3760A
401-05767
Fuses: 2x 800 mA; 6,25A; 8A
MM-6 Low: 10", 15 Ohm
Mid: 6", 10 Ohm
High: 3" 10 Ohm
Röhrenamp 50W R-R-4359A: 5U4GB, 2x 12AX7, 4x 7868
Pre-Amp: R-4372
Transistor 100W
: R-3760A
401-05767
RI-1 Low: 10", 9 Ohm
High: 6", 8,5 Ohm
Stereo 50W: R-4572
Power Amplifier stereo 50W: 4359A
Preamp stereo: 3800
Preamp Mono: 3800
#401-5767
RI-1G Low: 10", 9 Ohm
High: 6", 8,5 Ohm
Stereo 50W: R-4572
2x 12AX7, 4x 7868
Preamp stereo: 3800
#401-06703, 250W
Fuses: 10A; 2x 2A
#401-0656 (ALT. for 220V/110V)
TI-1 Low: 10" 15 Ohm
Mid: 6" 10 Ohm
High: 3" 10 Ohm
Röhrenamp 50W R-4359A: 2x 12AX7A, 4x 7868
Pre-Amp: R-4372
Transistorverstärker R-3760A -
100W
CTI-1 Crestwood Low: 10" 9 Ohm
Mid: 6" 10 Ohm
High 3" 10 Ohm
50W: 601-4359
100W: 601-3760
Potentiometer: 2x10 KΩ
601-06703
CTI-1C Crestwood Low: 10" 17 Ohm
Mid: 6" 10 Ohm
High 3" 10 Ohm
64W: 60-2179
120W: 601-7405
601-06703
TI-2 Low: 10" 15 Ohm
Mid: 6" 10 Ohm
High: 3" 10 Ohm
Röhrenverstärker 50W R-4359A: 2x 12AX7, 4x 7868
Pre-Amp: R-4372
100W
Fuse: 2x 2A; 3.2A
401-06703, 250W
Fuses: 10A; 2x 2A
R-74 Low: 10" 15 Ohm
Mid: 6" 10 Ohm
High: 3" 10 Ohm
Transistorverstärker # 602-02179: 64 Watt, Stereo
Transistorverstärker # 601-07405: 120 Watt, Stereo
R-80 Low: 10"
Mid: 6"
High: 3"
Pre-Amp: 3800 or 3758-B
Pre-Amp: R3758-B
#401-06703
R-80S Low: 10"
Mid: 6"
High: 3"
Pot: 2x10 KΩ
401-06894 (120V)
402-65079 (220V)
RI-2 Low: 10"
High: 6"
Pot: 2x10 KΩ
401-06894 (120V)
402-65079 (220V)
R-81 Low 10"   |   Mid-High 6"
Frequency 50 - 15000 Hz
64 Watt Stereo: # 606-02179
Pre-Amp: # 602-03758
401-06894
R-82 Low: 10",
Mid/High stereo: 6"
Mid/High mono: 5.25"
401-06894 (120V)
402-65079 (220V)
CTI-1SC Camelot Low: 10" 17 Ohm
Mid: 6" 10 Ohm
High: 3" 10 Ohm
Pot: 2x10 KΩ (stereo); 10 KΩ (mono) 401-06894 (120V)
402-65079 (220V)
R-83 Low: 10"
Mid/High stereo: 6"
125 Watt Stereo: # 601-07438
125 Watt Pre-Amp: # 601-08552
401-06894 (120V)
402-65079 (220V)
RI-3 Low: 8" 8 Ohm
High: 4.5" 12 Ohm
# 6-09166-01 (50W)
4-07313-01 (120V)
4-65087-02 (220V)
4-65087-03 (240V)
R-84 Low: 10", 30 Ohm
Mid/High: 6", 8.5 Ohm
Pre-Amplifier: 6-08552-01
125 Watt: # 6-07438-02
4-07313-01 (120V)
4-65087-02 (220V)
4-65087-03 (240V)
CTI-2 Kentwood Low: 12", 32 Ohm
R-85 Low: 10", 30 Ohm
Pot
4-07313-01 (120V)
4-65087-02 (220V)
4-65087-03 (240V)
RI-4 Carbonneau Low: 8", 8 Ohm -
#4-07469-01
Mid/High: 4.5", 12 Ohm
# 6-09189-02
4-07706-01 (120V)
4-65062-02 (220V)
4-65092-03 (240V)
RI-5 Carbonneau Low: 8", 8 Ohm -
#4-07469-01
# 6-09189-02
4-07706-01 (120V)
4-65062-02 (220V)
4-65092-03 (240V)
R-86 Low: 10", 30 Ohm
# 6-073438-04
4-07706-01 (120V)
4-65092-02 (220V)
4-65092-03 (240V)
CTI-3   125 Watt: # 6-07438-06
4-07706-01 (120V)
4-65092-02 (220V)
4-65092-03 (240V)
R-87 Low: 10", 30 Ohm
# 6-073438-06
4-07706-01 (120V)
4-65092-02 (220V)
4-65092-03 (240V)
R-88 Low: 10", 30 Ohm
Mid/High: 5-1/4", 8 Ohm
# 6-073438-06
4-07706-01 (120V)
4-65092-02 (220V)
4-65092-03 (240V)
R-89 Low: 10", 30 Ohm
# 6-073438-06
4-07706-01 (120V)
4-65092-02 (220V)
4-65092-03 (240V)
R-90 Woofer: 2x 10" 8 Ohm
Midrange:2x 5.75 " 8 Ohm
High: 2x 2"
# 6-09931-01 - 130 Watt 4-07706-03 (120V)
4-65092-05 (220V)
4-65092-06 (240V)
R-91 Woofer: 2x 10" 8 Ohm
High: 2x 2"
4-65092-05 (220V)
4-65092-06 (240V)
R-92 Woofer: 2x 10" 8 Ohm
High: 2x 2"
# 6-09931-02 4-07706-05 (120V)
4-65092-07 (220V)
4-65092-08 (240V)
R-93 Woofer: 2x 10" 8 Ohm
High: 2x 2"
4-65092-07 (220V)
4-65092-08 (240V)
R-94 Woofer: 2x 10" 8 Ohm
High: 2x 2"
4-65092-07 (220V)
4-65092-08 (240V)
Laserstar CD100 2x Woofer 10" Voice Coil 1-1/2"
8 Ohm
2x Midrange 6" Voice Coil 1"
8 Ohm
2x High 3" Voice Coil TBS
TBS
250 Watt, stereo: # 61024903
RCA 2N6284; RCA 2N6287
40862101 (115V);
40862150/51 (115/220V)
Wallphonos Storm, Berkeley, Sunrise, Starburst   250 Watt, stereo: #6112701 #40897301
CD MM-1   250 Watt, stereo: # 61024902
Q101: RCA 2N6284; Q102: RCA 2N6287
Nostalgia RNH   250 Watt, stereo: # 61024903
40862101 (115V);
Laserstar CD100G   250 Watt, stereo: # 61024903
Symphony 2x low 12",
2 mid-range, 2 tweeters
250 Watt, stereo
CD 100L 2x low 12",
250 Watt, stereo
Solara 2x low 12",
1,000-watt digital amp with 2-channel preamp;
70-volt transformer kit and dual
7-band equalizer
Solara 2
Modell - model - modéle
Lautsprecher - speaker
haut parleur
Verstärker + Pot   -   amplifier + pot
ampli + potentiomètre
Netzteil - power supply
allimentation
Fernwähler - Wallboxes
Modell - model
modéle
haut parleur
  Netzteil
power supply
Wallette WRA
Wallette WRB
Wallette WRE 3x5", 45 Ohm, 150-10,000 Hz. 4-07431-01
Stepper / Receiver
Modell - model
modéle
haut parleur
Netzteil
power supply
Netzteil
power supply
S40 / S80 / S120
L-235 Transformer – Fustat Ass.
<<<   zurück - back - retourner
