AMI und AMI/Rowe Musikboxen im Archiv von Jukebox-World |
ROWE/AMI MM-2 "Music Master" (1968) MM2A: with Dollar Bill Acceptor |
Vorgestellt im März 1968 Auch als Lizenzbau von National Instruments Pty. Ltd, Australia Vertrieb Europa: Amiro SA, Schweiz Besonderheiten:
Introduced in March 1968. Also built under license by National Instruments Pty. Ltd, Australia Vertrieb Europa: Amiro SA, Schweiz Special Features:
Designer:
Melvin Herman Boldt, patent D213,338 - filed 1968 |
MM2 - Music Master |
Vier auswechselbare Frontmotive
--- Four interchangeable front motives |
Australian version MM2 produced by National Instruments Pty. Ltd., Australia |
Photo courtesy of
Ken Reed |
Dia-Projektor – Slide Projector |
Service Manual: "A slide projector, mounted at the top center of the phonograph, shows slides promoting record play. The slide projector holds eight 35MM slides and shows then continuously | one every 15 seconds."
Photos and information courtesy of
Ken Reed
| Wahlen / Selections | 200 |
| Lampen / Lamps |
Door: 25W/T12/33" | Selector: 19W/28"/T8
| Title: 25W/33"/T12 | Credit & Dec. Panels: 12x #47 Slide Projector: CAD, 120V/75W max. |
| Verstärker / Amplifier |
50W: # 3812 / Pre-Amp: # 3758 or 100W: R-3760A / Pre-Amp: # 3758 Australian version: solid state amp 240 V - 25W mono amp as an option |
| Netzteil / Power supply |
401-05767 Fuses: 2x 800 mA, 6.25A, 8A |
| Lautsprecher / Speaker | # 603-03300 |
| Kreditgerät / Credit unit | 2x Low 10" 32 Ohm, 2x Mid-High 6" 16 Ohm |
| Mechanismus / Mechanism | 1100: # 606-03030 |
| Tonabnehmer / Cartridge | Shure M44 |
| Sicherungen / Fuses |
Amplifier 50W: 2A GMQ, 3A | Amplifier 100W: 3.2A GMQ,
4A Junction Box: 6.25A, 8A MDL , 2x 800mA | Credit Unit: 600 mA |
| Schlüssel / Key | C-440A |
| Abmessungen / Size | 132 x 103 x 66 cm / 51-3/4 x 40-1/2 x 25-7/8" | 165 kg |
| Zubehör / Accessories | Extra
speaker EX 401, EX 600, EX 700,
SGF |
Phono Vue | wallbox Wall-Ette
WRA, WRC | MAB Money Counter Gas-Alalrm-Horn-Kit | Wallbox Counter Bracket 201-12796 | Play-Me Feature Stepper CGA for Rowe/AMI wallbox | Stepper CGC for competitive 200 and 160 wallbox | Stepper CGD for Seeburg 3W1/3W100 Stepper CGE for Seeburg Consolette |
| Besonderheiten / Features |
