Attention: Please read notes below regarding Brexit, shipping information and closing time.
Gas spring 700N
Product 35 of 96
Item #: WD155
Atlanta, X9, X200, Estrella, Caravelle, SL600 - SL800
Cart deactivated
The Deutsche Wurlitzer lists these gas springs as a pneumatic fall support, NSM called them piston rod" and the term "gas strut" can be found as well as "gas spring". We decided to use the last term.
This gas spring is used on various Deutsche Wurlitzer models. The orig. part no. is 00 290 000 83.
We produce these fall supports with a force of 700N than the originally used 600N. This keeps the open door more steady.
Length  max. 530 mm
Stroke max.
220 mm
Extension force 700 Newton
Models Deutsche Wurlitzer
Atlanta 1979, 1980, 1981
X 9, X 200
Baccarole, Caravelle, Estrella
SL600, SL700, SL800
Please compare the given data with the original gas spring. One gas spring per jukebox is required only.
Reviews
ALFRED writes: 01.12.2017
Die Feder passt gut als Ersatz für die 550mm Feder der SL600,es fehlen ca.3cm Höhe bei aufgeklapptem Deckel,die Federkraft ist erheblich stärker und die Haube schiesst im erstem Moment richtig auf - trotzdem - ich würde die Feder wieder kaufen!
* incl. tax, plus shipping
