Attention: Please read notes below regarding Brexit, shipping information and closing time.
Ballast 13W / 230V
Product 12 of 15
Old ballasts can cause disturbing noise and might be a danger if the shielding of the wires is brittle. We recommend to replace old ballasts.
Values: 13 Watt 230 Volts
Size: L 90 mm x W 40 mm x H 28 mm
This ballast is rated for 13 Watt fluorescent lamps operated at 230 Volts. This can be suitable for jukeboxes
- operating at 230V regularly, e.g. models of NSM, Tonomat
- of US manufactuerers prepared for export already - compare ID plate
- or the jukebox was converted to 230V at a later date.
Please check if the heat resistant material underneath the ballast is still ok.
A general note: To operate fluorescent lamps in jukeboxes three devices are needed: The ballast, the lamp itself and a starter. They have to match each other in value and voltage.
Reviews
* incl. tax, plus shipping
