Please see notes below.
Gripper motor 110V
Product 8 of 81
Item #: A008
new, for AMI K (late series), Lyric and Continental
Cart deactivated
These motors for the later K, Lyric and Conti models were made exclusively for us in the U.S.A.
They are designed to operate at 110 volts AC.
The gear box had been improved and is stronger than on the original old motors.
The gear pitches and pressure angles are all changed to handle much higher loading.
Also the coil is thermally protected to prevent any type of burn-out. 7.3 RPM.
Different than other motors which are available elsewhere our motors can be connected directly to the 110 Volt line.
No extra transformer is needed!
The motor will be delivered without link and bracket. These parts can be reused from the old motors.
We made a 240 Volt version as well - see item A105.
The mounting bracket is offered as item A009, crank and link as A108 and A109.
The photo shows the 240 Volt version (physically same).
Note:
Limited availability.
Reviews
* incl. tax, plus shipping
