AMI D - G120
Years 1951 to 1955
Models D40, E40, F40 and G40 were offered for 78 ROM while E80, F80, G80 and 120 played already 45 RPM records. Both staying with the old style and offering the new 45 rpm record were kept for several years.
Pages: 1 2
  • Turntable drive belt
    AMI D80, E80 and E120, set - for 50 Hz.
    Item #: A701
    Cart deactivated
  • Idler wheel 78 RPM
    AMI Modelle A, B, C, D40, E40 - 78 RPM
    Item #: A700
    Cart deactivated
  • Idler wheel
    AMI F80 - Conti and some BAL-AMI, 45 rpm
    Item #: A006
    Cart deactivated
  • Rubber ring for idler wheel
    AMI F80 to Continental 2 (45 rpm) and BAL-AMI
    Item #: A190
    Cart deactivated
  • Idler tension spring
    AMI F80/120 and up and BAL-AMI
    Item #: A003
    Cart deactivated
  • 50 Hz conversion spring
    to convert 60 Hz TT-motors to 50 Hz
    AMI F80 and up to models 1979
    Item #: A010
    Cart deactivated
  • Spring plate below tonearm
    to adjust tonearm weight
    Item #: A220
    Cart deactivated
  • TT-grommets, set
    for various Rock-Ola and AMI jukeboxes
    Item #: RO080
    Cart deactivated
  • Turntable grommets, type A
    AMI, BAL-AMI, IMA/AMI, Jensen - set of 3 pcs.
    Item #: A100
    Cart deactivated
  • Distance sleeves AMI
    for TT grommets AMI, BAL-AMI, Jensen, IMA/AMI
    Set of 3 pcs.
    Item #: A012
    Cart deactivated
  • Motor brushes AMI
    for gripper and magazin motors of various models
    Item #: A002
    Cart deactivated
  • Outer ring for TT, velvet
    AMI D 80 and up, BAL-AMI, Jensen, IMA-AMI
    Item #: A120
    Cart deactivated
  • Operator card, salmon
    for various AMI models
    Item #: A600
    Cart deactivated
  • Operator card, mint
    Item #: A601
    Cart deactivated
  • Decal for H-338 volume control
    self-adhessive, for F - I mono
    Item #: A077-M
    Cart deactivated
  • E12 miniature screw 120V/6-10W
    110-140 Volt, 50-70mA, 6-10 Watt
    models AMI G and Swiss Discomatic
    Item #: LE12-11
    Cart deactivated
  • AMI cabinet key
    various master keys
    please choose key number
    Item #: SCH-AMI
    Cart deactivated
  • Cover discs
    for holes caused by Gauselmann safes
    Item #: V052
    Cart deactivated
  • Tracking Force Gauge (0-10 g)
    to adjust the tone arm weight
    Item #: WE010
    Cart deactivated
  • Item #: HBAS40K
    Cart deactivated
Pages: 1 2
* incl. tax, plus shipping
