Switches, Relays, and EAROM
Micro switches, main switch and relais
Faulty micro switches and relays cause malfunction of a jukebox. Do not rely on the clicking noise of the switch, it might be faulty though. Some sitches can be replaced with new ones, others have to be cleaned, overhauled, or being found as an original spare part.
  • EAROM ER-1400
    timekeeper, for NSM control and credit units with ES, ESII, ESIII and ESIV technology, new
    Item #: ER1400
    Cart deactivated
  • Cut-off switch
    AMI G200 to Conti 2, some BAL-AMI, Wurlitzer 2600 and up, Sonata 1050
    Item #: A090
    Cart deactivated
  • Push button
    chrome plated, e.g. for cancel button
    Item #: E042
    Cart deactivated
  • Cut-off switch
    for tone arm JAL - R-83
    >>> Please read the note in item description.
    Item #: A205
    Cart deactivated
    Available again.
  • Trip switch
    for Seeburg M100B - PFEA1U/APFEA1, U100, Console and Library Units
    Item #: S010
    Cart deactivated
  • Spring for Trip Switch
    for Seeburg M100B to PFEA1U/APFEA1
    Item #: S014
    Cart deactivated
  • Microswitch BZ-2R
    for many AMI, Rock-Ola and Wurlitzer jukeboxes
    price each
    Item #: E095
    Cart deactivated
  • Microswitch
    Rock-Ola models 434 - 484
    Item #: RO310
    Cart deactivated
  • Micro switch without lever - 4.8 mm
    1U / 16A / 250 VAC - terminals 4.8 mm
    Item #: E103
    Cart deactivated
  • Micro switch with short lever
    1U / 16A / 250 VAC
    Deutsche Wurlitzer with horizontal record player
    Item #: WD020
    Cart deactivated
  • Relay, 12 VDC - yellow
    replaces US Wurlitzer and Sonata 137088
    Item #: W751
    Cart deactivated
  • Relay, 24 VAC - red
    replaces Rock-Ola 45305, US Wurlitzer and Sonata 122366, Rowe F-12482
    Item #: RO315
    Cart deactivated
  • Relay, 24 VDC - white
    replaces Rock-Ola 43561, US Wurlitzer and Sonata 122133, AMI/Rowe F-12751 resp. 200-12751, Seeburg 44-509802
    Item #: RO316
    Cart deactivated
  • Relay, 24 VDC, 3PDT
    replaces Rock-Ola relay 49257 in models 453 to 494 and relays F-12274 in AMI/Rowe Phonovue
    Item #: RO318
    Cart deactivated
* incl. tax, plus shipping
