AMI G200
Year: 1956
With model G-200 AMI presented its new mechansim for 200 selections offering a rotating magazin in the back: record changer model 900. This type of "Multi-Selective" record changer was used for several years up to early models of K-series.
Pages: 1 2
  • Holder for Pin Pusher
    aluminium, AMI #3477
    Item #: A104
    Cart deactivated
  • Magazine belt
    AMI G-200 to Conti 2
    Item #: A001
    Cart deactivated
  • Pulse converter cover
    models G-200 to Conti 2
    Item #: A040
    Cart deactivated
  • Outer ring for TT, velvet
    AMI D 80 and up, BAL-AMI, Jensen, IMA-AMI
    Item #: A120
    Cart deactivated
  • Motor brushes AMI
    for gripper and magazin motors of various models
    Item #: A002
    Cart deactivated
  • Rubber sleeve
    for mechanisms cut-off G200 to J200
    Item #: A089
    Cart deactivated
  • Idler wheel
    AMI F80 - Conti and some BAL-AMI, 45 rpm
    Item #: A006
    Cart deactivated
  • Rubber ring for idler wheel
    AMI F80 to Continental 2 (45 rpm) and BAL-AMI
    Item #: A190
    Cart deactivated
  • Idler tension spring
    AMI F80/120 and up and BAL-AMI
    Item #: A003
    Cart deactivated
  • Turntable grommets, type A
    AMI, BAL-AMI, IMA/AMI, Jensen - set of 3 pcs.
    Item #: A100
    Cart deactivated
  • Distance sleeves AMI
    for TT grommets AMI, BAL-AMI, Jensen, IMA/AMI
    Set of 3 pcs.
    Item #: A012
    Cart deactivated
  • Cut-off switch
    AMI G200 to Conti 2, some BAL-AMI, Wurlitzer 2600 and up, Sonata 1050
    Item #: A090
    Cart deactivated
  • Tone arm cam keeper spring
    Phosphorous bronze
    Item #: A007
    Cart deactivated
  • Spring plate below tonearm
    to adjust tonearm weight
    Item #: A220
    Cart deactivated
  • Needle brush wire, type A
    models G, J, K, Conti and Lyric
    Item #: A015
    Cart deactivated
  • Needle brush
    for most US jukeboxes
    Item #: V092
    Cart deactivated
  • 50 Hz conversion spring
    to convert 60 Hz TT-motors to 50 Hz
    AMI F80 and up to models 1979
    Item #: A010
    Cart deactivated
  • Operator card, mint
    for various AMI models
    Item #: A601
    Cart deactivated
  • Operator card, salmon
    Item #: A600
    Cart deactivated
  • Decals for R-145 amplifier
    3-pcs. set, self-adhessive
    Item #: A078
    Cart deactivated
Pages: 1 2
* incl. tax, plus shipping
