General AMI parts
which go beyond each model necessary
Some parts are used not in one AMI model only, while others can be used across more models if liked.
Pages: 1 2
  • Tracking Force Gauge (0-10 g)
    to adjust the tone arm weight
    Item #: WE010
    Cart deactivated
  • Plug button, plastic
    mechanism cover AMI I and others, black
    Item #: A020-K
    Cart deactivated
  • Operator card, mint
    for various AMI models
    Item #: A601
    Cart deactivated
  • Operator card, salmon
    Item #: A600
    Cart deactivated
  • Frame for AMI operator card
    high gloss, 95 x 49 mm
    Item #: A019
    Cart deactivated
  • Turntable grommets, type A
    AMI, BAL-AMI, IMA/AMI, Jensen - set of 3 pcs.
    Item #: A100
    Cart deactivated
  • Distance sleeves AMI
    for TT grommets AMI, BAL-AMI, Jensen, IMA/AMI
    Set of 3 pcs.
    Item #: A012
    Cart deactivated
  • 50 Hz conversion spring
    to convert 60 Hz TT-motors to 50 Hz
    AMI F80 and up to models 1979
    Item #: A010
    Cart deactivated
  • Idler tension spring
    AMI F80/120 and up and BAL-AMI
    Item #: A003
    Cart deactivated
  • Tone arm cam keeper spring
    Phosphorous bronze
    Item #: A007
    Cart deactivated
  • Spring plate below tonearm
    to adjust tonearm weight
    Item #: A220
    Cart deactivated
  • Cut-off switch
    AMI G200 to Conti 2, some BAL-AMI, Wurlitzer 2600 and up, Sonata 1050
    Item #: A090
    Cart deactivated
  • Microswitch BZ-2R
    for many AMI, Rock-Ola and Wurlitzer jukeboxes
    price each
    Item #: E095
    Cart deactivated
  • Micro switch without lever - 4.8 mm
    1U / 16A / 250 VAC - terminals 4.8 mm
    Item #: E103
    Cart deactivated
  • Motor brushes AMI
    for gripper and magazin motors of various models
    Item #: A002
    Cart deactivated
  • Outer ring for TT, velvet
    AMI D 80 and up, BAL-AMI, Jensen, IMA-AMI
    Item #: A120
    Cart deactivated
  • Item #: A303
    Cart deactivated
  • Item #: A300
    Cart deactivated
  • Turntable-insert "Circles"
    for turntables AMI H
    Item #: A304
    Cart deactivated
  • Decal "ON-OFF-SCAN"
    for various AMI mechanism covers
    Item #: A132
    Cart deactivated
Pages: 1 2
* incl. tax, plus shipping
