ROWE/AMI 1963 and later
JAL, JEL, JBM, JAN, JAO, MM1 - MM6, CMM1 - CMM5, RI1 - RI3, CTI1 - CTI2, TI1 - TI2, R74 - R94
Already in 1959 AMI was acquired by "Canteen Automatic" and merged with their division "Rowe AC", a manufacturer for coin operated vending machines. This name can be found on id plates not before model JBM in Oct. 1963. The mechanism 1100 of Rowe models could be converted easily to 100, 160 and 200 selections.
Pages: 1 2 3
  • Control Amplifier R-2680 C-D
    Models JBM - Tropicana
    original, not tested
    Item #: 109-DR
    Cart deactivated
  • Magazine belt Rowe
    Models JAL to R-83, except CMM series
    Item #: A209
    Cart deactivated
  • Drive belt for turntable 33-1/3 RPM and animation
    Turntables Wurlitzer 2600, 2700, 2800 and animation AMI/Rowe JAN, JAO - 50 cy.
    Item #: W004-33
    Cart deactivated
  • Cut-off switch
    for tone arm JAL - R-83
    >>> Please read the note in item description.
    Item #: A205
    Cart deactivated
    Available again.
  • TT-bushing AMI, type B
    for TT motors AMI K and up
    Item #: A211
    Cart deactivated
  • 50 Hz conversion spring
    to convert 60 Hz TT-motors to 50 Hz
    AMI F80 and up to models 1979
    Item #: A010
    Cart deactivated
  • Idler wheel 33/45 rpm
    AMI Continental and Rowe starting with JAL/JEL using Intermix (33 und 45 rpm), 3 mm shaft, height 9,5 mm
    Item #: A195
    Cart deactivated
  • Idler wheel, 45 RPM
    JAL and up, for 3 mm shaft, height 14,5 mm
    Item #: A200
    Cart deactivated
  • Idler tension spring
    AMI F80/120 and up and BAL-AMI
    Item #: A003
    Cart deactivated
  • TT-grommets, set
    for various Rock-Ola and AMI jukeboxes
    Item #: RO080
    Cart deactivated
  • Operator card, mint
    for various AMI models
    Item #: A601
    Cart deactivated
  • Operator card, salmon
    Item #: A600
    Cart deactivated
  • Ba15d miniature lamp 110V/10W
    6S6DC - 110-140V, 60-90mA, 6-10W
    e.g. >z.B. for JBM, JAL, JEL, Wurlitzer 4008
    Item #: L15d-01
    Cart deactivated
  • T5 wedge base lamp #2321
    12 Volt, 80 mA, 1 Watt - GE #2321
    Item #: L2321
    Cart deactivated
  • Wire terminal lamp #1764
    28 Volt, 40 mA, 1,1 Watt - GE #1764
    used in some Rowe pre-amplifier
    Item #: L1764
    Cart deactivated
  • Micro switch without lever - 4.8 mm
    1U / 16A / 250 VAC - terminals 4.8 mm
    Item #: E103
    Cart deactivated
  • Relay, 24 VDC - white
    replaces Rock-Ola 43561, US Wurlitzer and Sonata 122133, AMI/Rowe F-12751 resp. 200-12751, Seeburg 44-509802
    Item #: RO316
    Cart deactivated
  • AMI cabinet key
    various master keys
    please choose key number
    Item #: SCH-AMI
    Cart deactivated
  • Cover discs
    for holes caused by Gauselmann safes
    Item #: V052
    Cart deactivated
  • Tracking Force Gauge (0-10 g)
    to adjust the tone arm weight
    Item #: WE010
    Cart deactivated
Pages: 1 2 3
* incl. tax, plus shipping
