Motor coupler
Product 20 of 48
Item #: JU010
Jupiter and Bergmann (Bergmann from 1966 and up)
Cart deactivated
Exact reproduction of the rubber coupler used in the mechanism of the Jupiter models (Electro-Kicker) and Bergmann models from 1966 and up (Concorde, Hawaii, Tahiti etc.) using Jupiter technology.
Length: 35 mm
Hole sizes: 4 and 7 mm
Jupiter
Jupiter 100, 104, 104S,  120, 102S, 120SL, B60, B96, M96, C96, D96,  120C, E80, E100, F100, 120M, 120R, 120Rs, 100G, 120G, 160G, 80H, 100H, 120H, 160H, 80K, 100K, 160K, 80L, 100L, 120L, 160L, 120LS, 160LS, 120B, 100N, 120N; eventually early models 100NS, 120NS
Bergmann
Concorde, Tahiti, Hawaii, Palm Beach, Rustic, Cirkon, Président, Safir, 100K, Mirage, Astral, 100L, Mystère, 120R, 160LS
The grafic shows part of the mechanism with the coupler marked as #6.
The needed allan key is included.
Note: Later models produced by Atari and Europe Electronique use a different motor coupler. We got said they have the same length but with smaller diameter of the holes. These are models Victory 100NS, Prodige 120NS, Rubis, Concerto 120, Hit-Parade, Rustica 160, 60R, 140TR, 160 Square, and Satellite.
Manufacturer: Stamann Musikboxen, Schafskamp 2, D-27243 Prinzhöfte, stamann@jukebox-world.de
Product information
Reviews
Johann writes: 16.04.2024
Sehr zufrieden, könnte nicht besser sein. Danke
Leonardo writes: 08.02.2024
Di qualità come sempre,un po caro ma la qualità si paga, Jupiter 80 L
Gerhard writes: 30.12.2023
besten Dank die Teile für meine Jupiter Box wie immer prompt geliefert
Hervé writes: 23.11.2023
j'ai utilisé ce coupleur sur chaque jukebox Jupiter que j'ai restauré, il est identique à l'original.
c'est une très bon produit, il est juste un peu cher.
mis sur Palm Beach , S104, 100K
Jean-Claude writes: 02.05.2023
Pour un Jupiter 120. Sans soucis
Livraison rapide.
guy writes: 19.03.2023
Stamann a le monopole pour ce genre de pièce,et il en profite !!!.Trop cher,beaucoup trop cher pour un bout de caoutchouc et 2 bagues a chaque bout .....
Hervé writes: 30.01.2023
Parfait ,bonne longueur et j'ai fais la modification des diamètres pour l'adapter à mon Square 60S , tout fonctionne.
franck writes: 28.09.2022
Rapide, pièce conforme à la description. Au top !!
Leonardo writes: 08.07.2022
Fast delivery. Item fits jukebox exactly. Same works perfectly, great seller. Thank you
Dion writes: 22.03.2022
toujours au top de l'efficacité
Carmelo writes: 01.07.2021
tutto ok materiale ottimo spedizione puntuale e accurata, grazie
Günther writes: 23.09.2020
Schnelle Lieferung. Artikel passt genau für Jupiter. Musikbox läuft wie neu. Danke
jean writes: 23.09.2020
livraison rapide, produit de très bonne qualité et conforme a la description.
Martin writes: 16.04.2020
Past prima,zeer goede kwaliteit en snelle levering
Klaus writes: 15.12.2019
Habe diese kuppelung fuer ein freund,hat zich gefreut .Leider hatten wir noch keine zeit,dass teil ein zu bauen.Wie gewohnt schnelle lieferung. Vielen dank.
* incl. tax, plus shipping
