R.O. 447 onwards
447, 448, 449, 450, 451, 452, 453, 454, 456, 459, 460, 461, 463, 464, 467, 469, 470, 471, 473 etc.
In October 1971 Rock-Ola presents it's new line with three major features: Sightline Programming, Numbers-Line-In-Selection-System and Rock-Power Amplifier. The program deck is up top, close to line of sight with the titelstrips tilted at the optimum reading angle. The new selection system is backed by electronic switching. By activating the Rock-Power Amplification Switch the volume could be doubled without sound distorsions.
Pages: 1 2 3 4
  • Back Door Cover
    original, for some 1970s models
    Item #: RORWD
    Cart deactivated
  • Display picture Rock-Ola 468
    original, for model Rock-Ola 468
    Item #: RO51444
    Cart deactivated
  • Mid range speaker
    Frequency 80 - 12kHz, Ø 130 mm, 8 Ohm
    Item #: SPMG130
    Cart deactivated
  • Scan-switch knob
    for many Rock-Ola jukeboxes
    Item #: RO095
    Cart deactivated
  • TT-bushing Rock-Ola
    for Rock-Ola TT-motors 1448 and up
    Item #: RO083
    Cart deactivated
  • Idler wheel
    some 1960s models, all 1970s up to Rock-Ola 1000, for Intermix 33/45 rpm, center hole Ø 4.55 mm
    Item #: RO112
    Cart deactivated
  • Idler tension spring
    for alll 45 rpm Rock-ola jukeboxes
    Item #: RO100
    Cart deactivated
  • 50 Hz conversion spring
    models 1455 and up
    Item #: RO091
    Cart deactivated
  • TT-grommets, set
    for various Rock-Ola and AMI jukeboxes
    Item #: RO080
    Cart deactivated
  • Tonearm grommets
    Models 1438 - 1485, pair
    Item #: RO131
    Cart deactivated
  • Screws for TT-motor
    size 6/32 x 5/8"; set
    Item #: RO085
    Cart deactivated
  • Tone arm spring
    to adjust pressure of "Accu-Trac" tone arms
    Item #: RO122
    Cart deactivated
  • Tone arm cam keeper spring
    0.2 mm phosphorus bronce
    Item #: RO120
    Cart deactivated
  • Relay, 24 VDC - white
    replaces Rock-Ola 43561, US Wurlitzer and Sonata 122133, AMI/Rowe F-12751 resp. 200-12751, Seeburg 44-509802
    Item #: RO316
    Cart deactivated
  • Relay, 24 VAC - red
    replaces Rock-Ola 45305, US Wurlitzer and Sonata 122366, Rowe F-12482
    Item #: RO315
    Cart deactivated
  • Relay, 24 VDC, 3PDT
    replaces Rock-Ola relay 49257 in models 453 to 494 and relays F-12274 in AMI/Rowe Phonovue
    Item #: RO318
    Cart deactivated
  • Ba15s current limiting lamp #309
    in credit units Rock-Ola 1493 - 474 - GE #309
    Item #: L309
    Cart deactivated
  • Microswitch
    Rock-Ola models 434 - 484
    Item #: RO310
    Cart deactivated
  • Micro switch without lever - 4.8 mm
    1U / 16A / 250 VAC - terminals 4.8 mm
    Item #: E103
    Cart deactivated
  • Motor brushes type C, basic
    for 70's gripper and magazin motors
    Item #: RO062
    Cart deactivated
Pages: 1 2 3 4
* incl. tax, plus shipping
