Rock-Ola 424 - 446
Rock-Ola 424, 425, 426, 429, 431, 432, 433, 434, 435, 436, 437, 440, 441, 442, 443, 444, 445, 446
Years 1964 - 1971: The previously visible mechanism was hidden step by step. First it could be seen through a small window, later it was completely covered by the title glasses. First attempts with transistorized technology was done in the mid Sixties, but Rock-Ola returned to well prooven valve technology for another couple of years. The selection system was still electro-mechanical using numbers and letters.
Pages: 1 2 3 4
  • Rock-Ola Turntable
    original, various to choose from
    Item #: ROTT
    Cart deactivated
  • Tweeter Rock-Ola 437, pair
    for models 433, 435, 436, and 437 - original
    Item #: 42735
    Cart deactivated
  • Rock-Ola 437 - Ultra
    parts machine - possibility for a request
    Item #: 437
    Cart deactivated
  • Classification strips, German
    black, set of 16 pcs.
    Item #: RO053-DE
    Cart deactivated
  • Classification strips, English
    Item #: RO053-EN
    Cart deactivated
  • Item #: RO650
    Cart deactivated
  • Lettering * ROCK-OLA *
    for models 404, 408, 414, 418 and others
    Item #: RO332
    Cart deactivated
  • Decals record magazine 434 et al.
    100 selction models 434, 435, 436, 441, 443, 445
    Item #: RO689
    Cart deactivated
  • TT insert Capri and Rhapsody
    for models 404, 408, 414 and 418
    Item #: RO139
    Cart deactivated
  • Velvet ring for turntable, grey
    on outer rim; for turntable models 1455 and up
    Item #: RO142
    Cart deactivated
    Available again!
  • Velvet ring for turntable, black
    for outer rim on TT, models 1455 and up
    Item #: RO143
    Cart deactivated
  • Relay, 24 VDC - white
    replaces Rock-Ola 43561, US Wurlitzer and Sonata 122133, AMI/Rowe F-12751 resp. 200-12751, Seeburg 44-509802
    Item #: RO316
    Cart deactivated
  • Relay, 24 VAC - red
    replaces Rock-Ola 45305, US Wurlitzer and Sonata 122366, Rowe F-12482
    Item #: RO315
    Cart deactivated
  • Scan-switch knob
    for many Rock-Ola jukeboxes
    Item #: RO095
    Cart deactivated
  • Rubber ring for idler wheel
    Models 1455 - 1497, mostly 1488 - 1497, possibly for Capri, Rhapsody and some later models, 45 rpm only
    Item #: RO115
    Cart deactivated
  • Idler wheel
    some 1960s models, all 1970s up to Rock-Ola 1000, for Intermix 33/45 rpm, center hole Ø 4.55 mm
    Item #: RO112
    Cart deactivated
  • Idler tension spring
    for alll 45 rpm Rock-ola jukeboxes
    Item #: RO100
    Cart deactivated
  • TT-grommets, set
    for various Rock-Ola and AMI jukeboxes
    Item #: RO080
    Cart deactivated
  • Screws for TT-motor
    size 6/32 x 5/8"; set
    Item #: RO085
    Cart deactivated
  • Idler wheel
    Models 1455 - 1485, mostly 1488 - 1497, possibly for Capri, Rhapsody and some later models, 45 rpm only, centre hole Ø 5,4 mm = 7/32"
    Item #: RO111
    Cart deactivated
Pages: 1 2 3 4
* incl. tax, plus shipping
