TT rubber belt
Product 16 of 48
Item #: JU001
Jupiter up to 1974 and Bergmann 1966 and up using Jupiter equipment
Cart deactivated
This rubber ring replaces the original ring which is mounted on the turntable of the Jupiter models (Electro-Kicker).
It is also needed for Bergmann models 1966 and up which use the Jupiter technics - starting with models Concorde, Hawaii, Tahiti et al.
Worn or hardened rings cause sound problems like wow and flutter. The new ring doesn't need to be glued on.
Jupiter
J100, 104, 104S,  120, 120S, 120SL - Console
B60, B96, M96, C96, D96
E80, E100, 120C - Concorde,
F100, 120M - Mediterrean
120R - Rustic, 120Rs - Rustic
100G, 120G - Majesty, 160G - Président
80H, 100H, 120H - Majesty, 160H - Président
80K, 100K, 120K - Mirage, 160K - Président
80L, 100L, 120L - Mystère, 160L - Astral
120LS - Baccara, 160LS - Ambassador
120B - Mistral
100N - Victory, 120N - Prodige
120NS - Victory*, 120NS - Prodige*
*Note: These models might use drive belts JU051 instead of the rubber ring. Please compare in advance.
Bergmann
Concorde, Tahiti, Hawaii, Palm Beach, Rustic, Cirkon, Président, Safir, 100K, Mirage, Astral, 100L, Mystère, 120R, 160LS
The second picture shows an exerpt of the parts list and the last photo a still unrestored mechanism. The rubber ring JU001 and the rubber mounts W011 are marked.
Note: We do not know whether this rubber ring was also used in first models produced by Atari after taken over the Jupiter section. These are Rubis, Concerto 120, Hit-Parade, and Rustica 160. Please compare with belt JU051 as well.
The later produced jukeboxes by Europe Elèctronique use a drive belt instead as well - compare item JU050. Models: 60R, 140TR, 160 Square, and Satellite.
Manufacturer: Stamann Musikboxen, Schafskamp 2, D-27243 Prinzhöfte, stamann@jukebox-world.de
Product information
Reviews
Johann writes: 16.04.2024
Schnelle Lieferung, super Qualität. Danke, danke.
Alexis writes: 25.03.2024
Produit de qualité, envoi rapide, service client au top. La courroie est parfaite pour mon jukebox, c'est niquel, je recommande à fond !
Leonardo writes: 08.02.2024
Ottima qualità come sempre, un po caro, Jupiter 80 L
Hervé writes: 23.11.2023
j'ai utilisé cette courroie sur chaque jukebox Jupiter que j'ai restauré.
Elle est identique à l'original, et elle permet de retrouver une vitesse de rotation du disque stable.
c'est une très bon produit.
Palm beach, S104 et 100K
Jean-Claude writes: 02.05.2023
A donné à mon Jupiter 120 une nouvelle vie.
Livraison rapide sans accros.
jean-francois writes: 04.02.2023
Bonjour , Parfait, rapide très bonne qualité merci
Karl writes: 30.05.2022
Danke für die schnelle Lieferung. Ihr ward die einzige Rettung für meine Musikbox.*****
Waltraud writes: 14.05.2022
Vielen lieben Dank und Grüße aus von Herrn Fischer
Dion writes: 22.03.2022
Parfait comme toujours efficace et sympa bonne pièces
Jean-Marc writes: 28.01.2021
Parfait, rapide et bonne qualité
Merci
jean writes: 25.11.2020
parfait pour remplacer l'ancienne qui ce craqueler , Livraison rapide . Merci
Yvon writes: 08.11.2020
Très bon produit , bonne qualité , service impeccable.
CHENEVAL writes: 28.06.2020
Bonne qualité
Christina writes: 25.05.2020
Passt perfekt
Kurt writes: 25.05.2020
Passt perfekt hab ich schon in einem anderen GERÄT Jahren verbaut .
Qualität Super und Lieferung auch in schweren Zeiten TOP !
Marc writes: 07.03.2018
Goed product mag alleen iets strakker zijn
Maar verder goed
Dequidt writes: 28.01.2018
Good product, perfect use on Jupiter juboxes! note 5/5.
* incl. tax, plus shipping
