Gas spring 600N
Product 13 of 53
Item #: WD155
Atlanta, X9, X200, Estrella, Caravelle, SL600 - SL800, New York
Cart deactivated
The Deutsche Wurlitzer lists these gas springs as a pneumatic fall support, NSM called them piston rod" and the term "gas strut" can be found as well as "gas spring". We decided to use the last term.
This gas spring is used on various Deutsche Wurlitzer models. The orig. part no. is 0029000083 resp. 13841.
Length  max. 550 mm
Stroke max.
231 mm
Extension force 600 Newton
Models Deutsche Wurlitzer
Atlanta 1979, 1980, 1981
X9, X200
Baccarole, Caravelle, Estrella
SL600, SL700, SL800
New York
Please compare the given data with the original gas spring. One gas spring per jukebox is required only.
Note on the feedbacks from 2017 and 2022:
The rated gas springs were slightly shorter (530 mm) than the original ones (550 mm). To compensate for this, the force (N) was increased at that time.
The gas springs now available have a length of 550 mm (center of eye to center of eye) and a force of 600N, true to the original.
Manufacturer: Stamann Musikboxen, Schafskamp 2, D-27243 Prinzhöfte, staman@jukebox-world.de
Product information
Reviews
Kurt writes: 19.10.2022
Habe die Gasfeder eingebaut,ist zwar ein paar Zentimeter kürzer,funktioniert aber bestens.Kann ich nur weiterempfehlen.
ALFRED writes: 01.12.2017
Die Feder passt gut als Ersatz für die 550mm Feder der SL600,es fehlen ca.3cm Höhe bei aufgeklapptem Deckel,die Federkraft ist erheblich stärker und die Haube schiesst im erstem Moment richtig auf - trotzdem - ich würde die Feder wieder kaufen!
* incl. tax, plus shipping
