Neck casting
Product 42 of 54
So called "neck casting" which holds the curved title holder assembly on the Continental models. Due to improper transportation the original castings are often cracked or broken.
We offer high quality injection moulded reproductions which are nicely chrome plated.
All holes and threads are made. The four main bolts which connect the casting to the cabinet and all other screws have to be used again.
The casting comes without any screws yet.
We did reinforce the casting's construction (see picture #2) and increased the thickness of the rear part.
The holes in the cabinet/rear frame of the jukebox might need to get enlarged to 10 - 12 mm for an easy mounting (see picture 7).
The original holes are about 9 mm in diameter.
From our point of view the chrome plating is good.
Nevertheless there might be very little flaws (scratches, "pimpels") in the surface.
Seen from some distance these flaws can hardly be noticed.
We want to mention anyway.
Please order only if you can accept this!
Sand casted "necks" which are available elsewhere can't be compared with our item made by high pressure injection casting!
Manufacturer: Stamann Musikboxen, Schafskamp 2, D-27243 Prinzhöfte, email: stamann@jukebox-world.de
Product information
Reviews
Alex writes: 28.02.2024
Missed giving the star rating.
Would give more stars if there was more.
Same as Kevin, my Continental neck casting also arrived in Australia in 7 days.
Don't be in any doubt, quality is second to none.
KEVIN writes: 06.11.2022
My AMI Continental neck casing arrived in Australia today; only 7 days from ordering, a record time. I must thank you and commend you for your engineering; it was a perfect fit. I was surprised as nothing seems to fit nowadays, however, it has significantly improved the look of my machine. It was a bit of hard work putting it together as we had no idea how best to do it, however, we got there in the end and no drilling required. Anyone would think it was built by the Germans..ha..ha...perfection. Thank you.
Vladimiro writes: 30.09.2022
A reproduction of the finest quality, as we have always been used to getting from Mr. Stamann. I would say that it is undoubtedly better than the original in all respects.
Ernst writes: 24.05.2022
Sehr gute Qualität. Alles passt. Von der Bestellung bis zur Lieferung alles super.
paul writes: 23.11.2020
THIS IS A GREAT ITEM AND VERY WELL FINISHED EXCELLENT CHROME AND ALL BOLTS AND SCREWS FIT
AMY writes: 09.08.2020
Superbe qualité, la meilleur reproduction ( on peut même dire mieux que l'original !!!!)
Tom writes: 06.08.2020
WOW ... unbelievably PERFECT .... better than original with exquisite chrome and a perfect fit ... worth every penny !!!!!!
* incl. tax, plus shipping
